Hello
How can I remove the shadow on the fonts in icons on the desktop ? Thank
you.
hash
Hello
you.
hash
It's in Performance Options, Vistal effects tab. This is the long way
there... why it's not more easily accessible is a mystery.
Control Panel--System and Maintenance--Performance Info tools--Use tools to
improve performance--Advanced tools--Adjust Appearance and performance of
windows. Uncheck the dropshadow for icon labels. But be warned, the type is
only a white color. So if you have a light background it's hard to read.
Amazinf we cant set the desktop font color!!
"hash" <joeblogg@spam.com> wrote in message
news:uBtWK9L2HHA.5380@TK2MSFTNGP04.phx.gbl...
> Hello
> you.
> hash
Not correct. While you can't CHOOSE the font color, the font will
switch to black if the background is a light color.
Dave
Hi Hash,
If you would like some screenshots with those instructions by John, see the link.
Visual Effects Options
The best solution with maximum flexibility is to install Iconoid. It`s a
great little free programme that has some very useful facilities. Works fine
on Vista as well. Just google the word Iconoid.
"brink" wrote:
> hash;412510 Wrote:
> > Hello
> > Thank
> > you.
> > hash
> Hi Hash,
> the link.
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> _http://www.vistax64.com/ (\"http://www.vistax64.com/\")_
> *Please post feedback to help others.*
Hi. I don`t know as I have x32 system. It wouldn`t hurt to try it. If it
doesn`t work properly, just unistall it and delete it`s programme folder etc.
> > fine
> Hi Purpleman,
> Thank you for the Iconoid suggestion. It looks like a neat little
> program. Do you know if it works in x64 Vista as well? I did not see
> Vista listed in the supported OS list, so I am just assuming that it may
> only work in x32 Vista. ??
> Shawn
> brink
> _http://www.Vistax64.com (\"http://www.Vistax64.com\")_
| Similar Threads | ||||
| Remove Asian fonts how? | Kabuki Armadillo | Vista General | 0 | 24 Oct 2008 |
| Drop shadow in icon text | NoAntz | Vista General | 7 | 17 Jul 2008 |
| Desktop icon text shadow | Michael Chare | Vista General | 3 | 03 Jan 2008 |
| Can“t remove chinese fonts | Pekka Varis | Vista account administration | 0 | 18 Aug 2007 |
| Icon Fonts,shadow to dark? | Hans Kristian Berg | Vista General | 0 | 19 Jun 2006 |
