Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Hibernating and then try to connect to my wireless
Old 08-08-2007   #1 (permalink)
Chaanse
Problems trying to connect to the Internet after I have hibernated.
The problem is that the wireless connection won't start sometimes. It
sometimes starts but when I open my webbrowser it closes again...
If I restart my computer, everything works smothly.
Any ideas?
Running:
Vaio VGN-FE41M
Intel PRO/Wireless 3945ABG
Vista Home Premium
Old 08-08-2007   #2 (permalink)
SombreSire
RE: Hibernating and then try to connect to my wireless
Hello,
Can you try to install this new update KB938979, it refers to (at least) a
network problem when resuming from hibernate.
Can you please also check that the settings to allow Windows to turn off the
network card to save power is enabled ? We have had this problem on a few
machine and since we re-enabled this settings everything is ok.
Marc.
> Any ideas?
> Running:
> Vaio VGN-FE41M
> Vista Home Premium
Old 08-08-2007   #3 (permalink)
David
Re: Hibernating and then try to connect to my wireless
SombreSire wrote:
> Hello,
> Marc.
>> Any ideas?
>> Running:
>> Vaio VGN-FE41M
>> Vista Home Premium
I just installed that update a few minutes ago and it CAUSED a wireless
problem that i didn't have prior!! I had to TWICE resort to using the
"diagnose and repair" feature to restore internet access to my laptop.
After the second repair, it seems to be holding ok now, after a third
try. It failed coming out of hibernation and also failed coming out of
sleep. After doing a 'repair' two separate times, I tried hibernation
again, and it worked ok, as it used to work BEFORE installing the
update. I'm not sure just how much improvement MS has made to Vista
with this update.
Dave
Wireless Access is "Local Only" I can't connect to wireless connec Vista General
I cannot connect with wireless Network & Sharing
Changing Wireless Networks While Hibernating Doesn't Reconfigure D Vista networking & sharing
wireless won't connect Vista networking & sharing
wireless lap top cant connect Vista networking & sharing
