Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - System Restore Shadow Copy Problem
Old 08-08-2007   #1 (permalink)
rmeacham
Guest
I have a folder under C:\Users\username\Documents\Visual Studio 2005\Projects
that contains C# code and a compiled dll that is used in a few different
applications. When I perform a system restore, the entire c# folder is
restored back to the same point as the system restore point. I was able to
use the shadow copy feature to recover changes I made. However, performing a
system restore should not affect user data (in this case my c# code). Is
there a way to tell Vista that this is a user directory and not a system
directory.
Old 08-08-2007   #2 (permalink)
Rick Rogers
Guest
Re: System Restore Shadow Copy Problem
As you can read here:
http://www.microsoft.com/middleeast/...ne/backup.mspx,
the shadow copies of user data are now part of the system restore process.
To my knowledge, there is no way to single out folders and exempt them from
this process. I would consider moving the data, or even the entire user
accounts documents folder, to a different volume and ensuring that drive is
not monitored (System Protection tab of the advanced system properties).
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"rmeacham" <rmeacham@discussions.microsoft.com> wrote in message
news:390AFCE1-7C11-41F2-A860-B8B0410766F5@microsoft.com...
>2005\Projects
> to
> performing a
> directory.
Old 08-09-2007   #3 (permalink)
rmeacham
Guest
I would still think this is a bug. System restore should not replace user
data files.
"Rick Rogers" wrote:
> Hi,
> Best of Luck,
> >2005\Projects
> > to
> > performing a
> > directory.
Old 08-09-2007   #4 (permalink)
Rick Rogers
Guest
A bug by design. It's supposed to behave this way to replace any user files
with known good copies in the event of system corruption. Something that was
actually a common complaint in XP, that System Restore did not protect user
data. My thought is that more configurability would be a nice thing to
offer.
Best of Luck,
news:F9906709-7B38-4BBA-82A7-035CBD35AED5@microsoft.com...
> data files.
>> Hi,
>> process.
>> from
>> is
>> Best of Luck,
>> >2005\Projects
>> > different
>> > able
>> > to
>> > performing a
>> > Is
>> > system
>> > directory.
Old 08-09-2007   #5 (permalink)
rmeacham
Guest
I have a different folder at the same level that contains java code. The
system restore did not reset the java code folder. In fact as far as I can
tell no other user files on my machine were reverted back to the restore
point. Only this one folder. Do you know how, if this is by design, the
system restore decides what to restore and what to ignore?
> offer.
> Best of Luck,
> > data files.
> >> Hi,
> >> process.
> >> from
> >> is
> >> Best of Luck,
> >> >2005\Projects
> >> > different
> >> > able
> >> > to
> >> > performing a
> >> > Is
> >> > system
> >> > directory.
Old 08-09-2007   #6 (permalink)
Rick Rogers
Guest
To my knowledge, it doesn't "decide" anything other than to grab the shadow
copies when a system restore is invoked. Like I said, probably the simplest
solution would be to move the user account's document folder to another,
unmonitored volume.
Best of Luck,
newsA617ED7-D042-4206-8FB6-65A9E104D316@microsoft.com...
> can
>> files
>> was
>> user
>> offer.
>> Best of Luck,
>> >user
>> > data files.
>> >> Hi,
>> >> process.
>> >> from
>> >> user
>> >> drive
>> >> is
>> >> properties).
>> >> Best of Luck,
>> >> >2005\Projects
>> >> > different
>> >> > is
>> >> > able
>> >> > to
>> >> > performing a
>> >> > code).
>> >> > Is
>> >> > system
>> >> > directory.
The Volume Shadow Copy service used by System Restore is not working. - help! Vista General
Volume Shadow Copy (VSS) - System Restore won't start Vista General
System Restore Points without shadow copy - there has got to be a way!! Vista file management
System Restore Points without shadow copy - there has got to be a way!! Vista performance & maintenance
System Restore Points without shadow copy - there has got to be a way!! Vista General
