| Guest | recycle bin icon does not empty I deleted the recycle bin accidentally. I restored it using Personalize/Change desktop icons. However, when I click on "Empty Recycle Bin" the bin greys out, but does not revert to an empty bin. The empty bin shows up only after I reboot. How can I fix this? Thank you. David Salmon |
| Guest | Re: recycle bin icon does not empty go to personalize and change the theme then get out and you can go back and change the theme back and your delete folder should start working again. "David Salmon" <DavidSalmon@xxxxxx> wrote in message news:F64ADE52-514F-4EF9-915F-EEF24BFDD95D@xxxxxx Quote: >I deleted the recycle bin accidentally. I restored it using > Personalize/Change desktop icons. However, when I click on "Empty Recycle > Bin" the bin greys out, but does not revert to an empty bin. The empty > bin > shows up only after I reboot. > > How can I fix this? > > Thank you. > > David Salmon |
| Guest | Re: recycle bin icon does not empty Darned if it didn't work! Thank you. David "John Lee Brown" wrote: Quote: > go to personalize and change the theme then get out and you can go back and > change the theme back and your delete folder should start working again. > "David Salmon" <DavidSalmon@xxxxxx> wrote in message > news:F64ADE52-514F-4EF9-915F-EEF24BFDD95D@xxxxxx Quote: > >I deleted the recycle bin accidentally. I restored it using > > Personalize/Change desktop icons. However, when I click on "Empty Recycle > > Bin" the bin greys out, but does not revert to an empty bin. The empty > > bin > > shows up only after I reboot. > > > > How can I fix this? > > > > Thank you. > > > > David Salmon > |
| Recycle Bin icon will not show empty without manual screen refresh.? | Vista General | |||
| Recycle Bin empty, icon changed correctly, and delete confirmation dialog closed | VB Script | |||
| Recycle Bin icon always looks empty? | Vista General | |||
| CHANGE RECYCLE BIN ICON - EMPTY FULL HOW? | Vista General | |||
| Recycle bin icon not filling/emptying when recycle bin is full/emp | Vista General | |||
