| | Heavy Battery Drain after Hibernation My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business and I have installed all the Lenovo and Vista updates. I fully charged the battery, then put the machine into hibernation and unplugged the AC adapter. After an overnight (8-10 hours) hibernation, the battery had lost 15-20% power. However, if I unplugged the AC adapter before hibernation, the battery didn't drain at all. Lenovo/IBM had already replaced my battery and motherboard to no avail. I believe Vista was unable to shutoff the power consumption of all the components. At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery drain issue is real and related to Vista updates. They found out that after reinstalling Vista, the battery didn't drain. The drain appeared only after installing around 19 Vista critical updates. The repair center admitted that the issue was too complicated for them to resolve alone. They've already requested assistance from their global tech support. Does anyone know the cause of battery drain and whether there is a solution or patch somewhere? |
| | RE: Heavy Battery Drain after Hibernation I too have this issue. I just noticed it this morning after seeing it happen two days in a row. I'm loosing 45% of my battery in 24 hours. I have a brand new Lenovo T61. I deleted the Lenovo partitions and installed Vista Enterprise fresh, installed all the latest drivers from Lenovo and all Vista updates. I'll be curious and anxious to see a fix for this. Frankly, I'm about ready to revert back to Windows XP Pro. Aside from application incompadibilities in Vista (which is severely limiting what I can do and support from my Vista machine) I used Hibernation in that OS for years without issue. I've had nothing but trouble with Hibernation in Vista on a T43 and two T61's. For now, I'm going to try unplugging the power source prior to going into hibernation mode. What a hokey solution. Joel "Ian" wrote: Quote: > My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business and I > have installed all the Lenovo and Vista updates. > > I fully charged the battery, then put the machine into hibernation and > unplugged the AC adapter. After an overnight (8-10 hours) hibernation, the > battery had lost 15-20% power. However, if I unplugged the AC adapter before > hibernation, the battery didn't drain at all. Lenovo/IBM had already replaced > my battery and motherboard to no avail. I believe Vista was unable to shutoff > the power consumption of all the components. > > At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery drain > issue is real and related to Vista updates. They found out that after > reinstalling Vista, the battery didn't drain. The drain appeared only after > installing around 19 Vista critical updates. > > The repair center admitted that the issue was too complicated for them to > resolve alone. They've already requested assistance from their global tech > support. Does anyone know the cause of battery drain and whether there is a > solution or patch somewhere? > > > |
| | Re: Heavy Battery Drain after Hibernation Vista Home Premium Normal operation for the start menu power button is sleep, not hibernate, if it is plugged in. If you have it plugged in, used the power button icon, it will go to sleep mode, it will save the system as if it is ready to hibernate (allow hybrid sleep turned on), and stay in sleep mode. When you unplug it stays in sleep using up the power. In the Power options you need to change the way the way the Power buttons and lid function. There are options to use when on battery and when plugged in. If you want machine to always hibernate when the Start menu power button is used for instance you need to set that for both On battery and Plugged in states. Power options, Advanced settings Power buttons and lid. You can tell if it actually hibernates or is sleeping. When you start it back up if it is almost immediately available then it was just sleeping. If it shows a busy bar running at the bottom of the screen then it is restoring from the hard drive and it did make it to hibernate. I am not sure from your post just how you are having the computer 'hibernate'. With the machine plugged in it will default to sleeping, it is tricky to get it to hibernate when plugged in with default settings. Michael "JF" <JF@xxxxxx> wrote in message news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx Quote: > I too have this issue. I just noticed it this morning after seeing it > happen > two days in a row. I'm loosing 45% of my battery in 24 hours. I have a > brand new Lenovo T61. I deleted the Lenovo partitions and installed Vista > Enterprise fresh, installed all the latest drivers from Lenovo and all > Vista > updates. I'll be curious and anxious to see a fix for this. Frankly, I'm > about ready to revert back to Windows XP Pro. Aside from application > incompadibilities in Vista (which is severely limiting what I can do and > support from my Vista machine) I used Hibernation in that OS for years > without issue. I've had nothing but trouble with Hibernation in Vista on > a > T43 and two T61's. > > For now, I'm going to try unplugging the power source prior to going into > hibernation mode. What a hokey solution. > > Joel > > > "Ian" wrote: > Quote: >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business >> and I >> have installed all the Lenovo and Vista updates. >> >> I fully charged the battery, then put the machine into hibernation and >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, >> the >> battery had lost 15-20% power. However, if I unplugged the AC adapter >> before >> hibernation, the battery didn't drain at all. Lenovo/IBM had already >> replaced >> my battery and motherboard to no avail. I believe Vista was unable to >> shutoff >> the power consumption of all the components. >> >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery >> drain >> issue is real and related to Vista updates. They found out that after >> reinstalling Vista, the battery didn't drain. The drain appeared only >> after >> installing around 19 Vista critical updates. >> >> The repair center admitted that the issue was too complicated for them to >> resolve alone. They've already requested assistance from their global >> tech >> support. Does anyone know the cause of battery drain and whether there is >> a >> solution or patch somewhere? >> >> >> |
| | Re: Heavy Battery Drain after Hibernation I have no doubt I did use hibernate a dozen times. The battery drain after hibernation is real and repeatable. Both Lenovo Hong Kong and Yamato Laboratory (Lenovo's famous R&D center in Tokyo) have both confirmed the issue. I had reinstalled Vista using the Lenovo recovery discs (2nd revision) 3 times; once on the original 5,400 rpm hard drive and twice on a new 7,200 rpm drive. Every time after I had finished installing Vista, I installed all the Windows and Lenovo updates (using System Update). I was very surprised to find out that the installation on the 5,400 rpm drive resulted in no battery drain. I charged the battery to 100% and waited 8-10 hours several times. However, the twice installations on the 7,200 rpm drive resulted in battery drain! I don't believe the 7,200 rpm has anything to do with the battery drain. I suspect the battery drain has something to do with the priority in installing Windows updates first or Lenovo updates first. Yamato suggested to uncheck the option "Allow this device to wake the computer" on the network card. However, it didn't resolve the issue. I strongly believe one or more buggy drivers are not able to turn off some components after hibernation resulting in the battery drain. Ian "Michael Walraven" wrote: Quote: > Vista Home Premium > Normal operation for the start menu power button is sleep, not hibernate, if > it is plugged in. > > If you have it plugged in, used the power button icon, it will go to sleep > mode, it will save the system as if it is ready to hibernate (allow hybrid > sleep turned on), and stay in sleep mode. When you unplug it stays in sleep > using up the power. > > In the Power options you need to change the way the way the Power buttons > and lid function. > There are options to use when on battery and when plugged in. > > If you want machine to always hibernate when the Start menu power button is > used for instance you need to set that for both On battery and Plugged in > states. > > Power options, Advanced settings Power buttons and lid. > > You can tell if it actually hibernates or is sleeping. When you start it > back up if it is almost immediately available then it was just sleeping. If > it shows a busy bar running at the bottom of the screen then it is restoring > from the hard drive and it did make it to hibernate. > > I am not sure from your post just how you are having the computer > 'hibernate'. With the machine plugged in it will default to sleeping, it is > tricky to get it to hibernate when plugged in with default settings. > > Michael > > > "JF" <JF@xxxxxx> wrote in message > news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx Quote: > > I too have this issue. I just noticed it this morning after seeing it > > happen > > two days in a row. I'm loosing 45% of my battery in 24 hours. I have a > > brand new Lenovo T61. I deleted the Lenovo partitions and installed Vista > > Enterprise fresh, installed all the latest drivers from Lenovo and all > > Vista > > updates. I'll be curious and anxious to see a fix for this. Frankly, I'm > > about ready to revert back to Windows XP Pro. Aside from application > > incompadibilities in Vista (which is severely limiting what I can do and > > support from my Vista machine) I used Hibernation in that OS for years > > without issue. I've had nothing but trouble with Hibernation in Vista on > > a > > T43 and two T61's. > > > > For now, I'm going to try unplugging the power source prior to going into > > hibernation mode. What a hokey solution. > > > > Joel > > > > > > "Ian" wrote: > > Quote: > >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business > >> and I > >> have installed all the Lenovo and Vista updates. > >> > >> I fully charged the battery, then put the machine into hibernation and > >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, > >> the > >> battery had lost 15-20% power. However, if I unplugged the AC adapter > >> before > >> hibernation, the battery didn't drain at all. Lenovo/IBM had already > >> replaced > >> my battery and motherboard to no avail. I believe Vista was unable to > >> shutoff > >> the power consumption of all the components. > >> > >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery > >> drain > >> issue is real and related to Vista updates. They found out that after > >> reinstalling Vista, the battery didn't drain. The drain appeared only > >> after > >> installing around 19 Vista critical updates. > >> > >> The repair center admitted that the issue was too complicated for them to > >> resolve alone. They've already requested assistance from their global > >> tech > >> support. Does anyone know the cause of battery drain and whether there is > >> a > >> solution or patch somewhere? > >> > >> > >> |
| | Re: Heavy Battery Drain after Hibernation Ian, My NIC also has a 'allow the computer to turn off this device to save power' option. As I understand, if the computer is on AC power when it is hibernated then the clock on the BIOS is set to wake the computer up, for instance at 3AM to check for Microsoft updates. If the computer is on battery power when it is hibernated, than the BIOS wakeup clock is not set. It is possible that the two drives have different power management capabilities. My drive says it supports D0 and D3 (Power Data property under Details Tab in Device manager). Interesting functionality displayed here, I will be watching for solutions or additional understanding of what is going on. My laptop is still XP so am not encountering your problem. Michael Vista Home Premium "Ian" <Ian@xxxxxx> wrote in message news:2A7B6554-6E5B-4FBF-BAF2-AC6B0EE7648E@xxxxxx Quote: > I have no doubt I did use hibernate a dozen times. The battery drain after > hibernation is real and repeatable. Both Lenovo Hong Kong and Yamato > Laboratory (Lenovo's famous R&D center in Tokyo) have both confirmed the > issue. > > I had reinstalled Vista using the Lenovo recovery discs (2nd revision) 3 > times; once on the original 5,400 rpm hard drive and twice on a new 7,200 > rpm > drive. Every time after I had finished installing Vista, I installed all > the > Windows and Lenovo updates (using System Update). I was very surprised to > find out that the installation on the 5,400 rpm drive resulted in no > battery > drain. I charged the battery to 100% and waited 8-10 hours several times. > However, the twice installations on the 7,200 rpm drive resulted in > battery > drain! > > I don't believe the 7,200 rpm has anything to do with the battery drain. I > suspect the battery drain has something to do with the priority in > installing > Windows updates first or Lenovo updates first. > > Yamato suggested to uncheck the option "Allow this device to wake the > computer" on the network card. However, it didn't resolve the issue. > > I strongly believe one or more buggy drivers are not able to turn off some > components after hibernation resulting in the battery drain. > > Ian > > > "Michael Walraven" wrote: > Quote: >> Vista Home Premium >> Normal operation for the start menu power button is sleep, not hibernate, >> if >> it is plugged in. >> >> If you have it plugged in, used the power button icon, it will go to >> sleep >> mode, it will save the system as if it is ready to hibernate (allow >> hybrid >> sleep turned on), and stay in sleep mode. When you unplug it stays in >> sleep >> using up the power. >> >> In the Power options you need to change the way the way the Power buttons >> and lid function. >> There are options to use when on battery and when plugged in. >> >> If you want machine to always hibernate when the Start menu power button >> is >> used for instance you need to set that for both On battery and Plugged in >> states. >> >> Power options, Advanced settings Power buttons and lid. >> >> You can tell if it actually hibernates or is sleeping. When you start it >> back up if it is almost immediately available then it was just sleeping. >> If >> it shows a busy bar running at the bottom of the screen then it is >> restoring >> from the hard drive and it did make it to hibernate. >> >> I am not sure from your post just how you are having the computer >> 'hibernate'. With the machine plugged in it will default to sleeping, it >> is >> tricky to get it to hibernate when plugged in with default settings. >> >> Michael >> >> >> "JF" <JF@xxxxxx> wrote in message >> news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx Quote: >> > I too have this issue. I just noticed it this morning after seeing it >> > happen >> > two days in a row. I'm loosing 45% of my battery in 24 hours. I have >> > a >> > brand new Lenovo T61. I deleted the Lenovo partitions and installed >> > Vista >> > Enterprise fresh, installed all the latest drivers from Lenovo and all >> > Vista >> > updates. I'll be curious and anxious to see a fix for this. Frankly, >> > I'm >> > about ready to revert back to Windows XP Pro. Aside from application >> > incompadibilities in Vista (which is severely limiting what I can do >> > and >> > support from my Vista machine) I used Hibernation in that OS for years >> > without issue. I've had nothing but trouble with Hibernation in Vista >> > on >> > a >> > T43 and two T61's. >> > >> > For now, I'm going to try unplugging the power source prior to going >> > into >> > hibernation mode. What a hokey solution. >> > >> > Joel >> > >> > >> > "Ian" wrote: >> > >> >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business >> >> and I >> >> have installed all the Lenovo and Vista updates. >> >> >> >> I fully charged the battery, then put the machine into hibernation and >> >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, >> >> the >> >> battery had lost 15-20% power. However, if I unplugged the AC adapter >> >> before >> >> hibernation, the battery didn't drain at all. Lenovo/IBM had already >> >> replaced >> >> my battery and motherboard to no avail. I believe Vista was unable to >> >> shutoff >> >> the power consumption of all the components. >> >> >> >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery >> >> drain >> >> issue is real and related to Vista updates. They found out that after >> >> reinstalling Vista, the battery didn't drain. The drain appeared only >> >> after >> >> installing around 19 Vista critical updates. >> >> >> >> The repair center admitted that the issue was too complicated for them >> >> to >> >> resolve alone. They've already requested assistance from their global >> >> tech >> >> support. Does anyone know the cause of battery drain and whether there >> >> is >> >> a >> >> solution or patch somewhere? >> >> >> >> >> >> |
| | #6 (permalink) |
| | Re: Heavy Battery Drain after Hibernation I am using the 5400 RPM drive which came with my T61. I can confirm that the option for hybrid sleep is not enabled (supposedly, this is by design in Vista on a Laptop, as it's intended for power savings when constantly plugged into AC). I am selecting "Hibernate" from the shutdown menu - not closing the lid. I do close the lid when I indend to just go to sleep. I do this frequently at home when I know it's going to be plugged into AC. I intentionally hibernate when I'm mobile and need to maximize my battery. When I hibernate, all the lights are turned off - including the cresent moon, which would indicate that it's asleep. When I experience battery drain, there aren't any event messages in the system event log, so I am pretty certain the laptop didn't power up to check for Windows updates. Unplugging the AC before selecting hibernate seems to prevent the battery drain. Still a dumb solution. Also, if this is by design, it's funny that Lenovo doesn't know about this. From Ian's post, Lenovo doesn't quickly replace batteries and motherboards on these laptops. The want to exhaust all troubleshooting they know of before replacing parts. I haven't yet tried pressing the eject button on my Lenovo dock, then hibernating. I'll try that later on today. Til now, I've been doing this strictly off the dock. Joel |
| | #7 (permalink) |
| | Re: Heavy Battery Drain after Hibernation Joel, Lenovo DID replace my battery promptly after my first compliant. When I complained the second time they replaced the motherboard. When I complained the third time, they delivered a newly installed hard drive (with Vista only, no Windows or Lenovo updates) to my home on a Saturday afternoon. All of the above attempts failed to fix the battery drain. However, Lenovo did mention that battery drain didn't appear when Vista was reinstalled (like the day you purchased your Lenovo). However, after installing the first several Vista updates (no Lenovo update), the battery drain appeared. During last weekend, I was able to install Vista on my original 5,400 rpm hard drive with all Vista and Lenovo updates. The battery drain DIDN'T appear. Battery drain first appeared on this same original hard drive 3 months ago. I also installed Vista on a new 7,200 rpm hard drive twice, unfortunately the battery drain appeared at both attempts. This led me to believe the drain has nothing to do with hard drives. At present, I firmly believe the battery drain is a software problem not hardware. It probably has something to do with updates installation. In another words, if you install update A first, the problem wouldn't appear. If you install B first, it will. How else could you explain my experiences? Ian "JF" wrote: Quote: > I am using the 5400 RPM drive which came with my T61. I can confirm that the > option for hybrid sleep is not enabled (supposedly, this is by design in > Vista on a Laptop, as it's intended for power savings when constantly plugged > into AC). > > I am selecting "Hibernate" from the shutdown menu - not closing the lid. I > do close the lid when I indend to just go to sleep. I do this frequently at > home when I know it's going to be plugged into AC. I intentionally hibernate > when I'm mobile and need to maximize my battery. When I hibernate, all the > lights are turned off - including the cresent moon, which would indicate that > it's asleep. When I experience battery drain, there aren't any event > messages in the system event log, so I am pretty certain the laptop didn't > power up to check for Windows updates. > > Unplugging the AC before selecting hibernate seems to prevent the battery > drain. Still a dumb solution. > > Also, if this is by design, it's funny that Lenovo doesn't know about this. > From Ian's post, Lenovo doesn't quickly replace batteries and motherboards on > these laptops. The want to exhaust all troubleshooting they know of before > replacing parts. > > I haven't yet tried pressing the eject button on my Lenovo dock, then > hibernating. I'll try that later on today. Til now, I've been doing this > strictly off the dock. > > Joel |
| | #8 (permalink) |
| | Re: Heavy Battery Drain after Hibernation Michael, The battery drain appeared on both my original 5,400 and the newly acquired 7,200 rpm drives. I installed Vista (with all the Vista and Lenovo updates) on both drives in the last couple of days. However, I don't know what I did RIGHT, I repeatedly hibernate my X61s several times and the battery drain didn't appear on my 5,400 rpm drive. I didn't have the same luck with my 7,200 rpm drive though! I believe I must have done something different installing my 5,400 rpm drive than my 7,200 rpm drive. I think it has something to do with which update I intall first. However, with so many Vista and Lenovo updates, it is unwieldy for me to figure out. Ian "Michael Walraven" wrote: Quote: > Ian, > My NIC also has a 'allow the computer to turn off this device to save power' > option. > > As I understand, if the computer is on AC power when it is hibernated then > the clock on the BIOS is set to wake the computer up, for instance at 3AM to > check for Microsoft updates. If the computer is on battery power when it is > hibernated, than the BIOS wakeup clock is not set. > > It is possible that the two drives have different power management > capabilities. My drive says it supports D0 and D3 (Power Data property under > Details Tab in Device manager). > > Interesting functionality displayed here, I will be watching for solutions > or additional understanding of what is going on. > My laptop is still XP so am not encountering your problem. > > Michael > Vista Home Premium > > > "Ian" <Ian@xxxxxx> wrote in message > news:2A7B6554-6E5B-4FBF-BAF2-AC6B0EE7648E@xxxxxx Quote: > > I have no doubt I did use hibernate a dozen times. The battery drain after > > hibernation is real and repeatable. Both Lenovo Hong Kong and Yamato > > Laboratory (Lenovo's famous R&D center in Tokyo) have both confirmed the > > issue. > > > > I had reinstalled Vista using the Lenovo recovery discs (2nd revision) 3 > > times; once on the original 5,400 rpm hard drive and twice on a new 7,200 > > rpm > > drive. Every time after I had finished installing Vista, I installed all > > the > > Windows and Lenovo updates (using System Update). I was very surprised to > > find out that the installation on the 5,400 rpm drive resulted in no > > battery > > drain. I charged the battery to 100% and waited 8-10 hours several times. > > However, the twice installations on the 7,200 rpm drive resulted in > > battery > > drain! > > > > I don't believe the 7,200 rpm has anything to do with the battery drain. I > > suspect the battery drain has something to do with the priority in > > installing > > Windows updates first or Lenovo updates first. > > > > Yamato suggested to uncheck the option "Allow this device to wake the > > computer" on the network card. However, it didn't resolve the issue. > > > > I strongly believe one or more buggy drivers are not able to turn off some > > components after hibernation resulting in the battery drain. > > > > Ian > > > > > > "Michael Walraven" wrote: > > Quote: > >> Vista Home Premium > >> Normal operation for the start menu power button is sleep, not hibernate, > >> if > >> it is plugged in. > >> > >> If you have it plugged in, used the power button icon, it will go to > >> sleep > >> mode, it will save the system as if it is ready to hibernate (allow > >> hybrid > >> sleep turned on), and stay in sleep mode. When you unplug it stays in > >> sleep > >> using up the power. > >> > >> In the Power options you need to change the way the way the Power buttons > >> and lid function. > >> There are options to use when on battery and when plugged in. > >> > >> If you want machine to always hibernate when the Start menu power button > >> is > >> used for instance you need to set that for both On battery and Plugged in > >> states. > >> > >> Power options, Advanced settings Power buttons and lid. > >> > >> You can tell if it actually hibernates or is sleeping. When you start it > >> back up if it is almost immediately available then it was just sleeping. > >> If > >> it shows a busy bar running at the bottom of the screen then it is > >> restoring > >> from the hard drive and it did make it to hibernate. > >> > >> I am not sure from your post just how you are having the computer > >> 'hibernate'. With the machine plugged in it will default to sleeping, it > >> is > >> tricky to get it to hibernate when plugged in with default settings. > >> > >> Michael > >> > >> > >> "JF" <JF@xxxxxx> wrote in message > >> news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx > >> > I too have this issue. I just noticed it this morning after seeing it > >> > happen > >> > two days in a row. I'm loosing 45% of my battery in 24 hours. I have > >> > a > >> > brand new Lenovo T61. I deleted the Lenovo partitions and installed > >> > Vista > >> > Enterprise fresh, installed all the latest drivers from Lenovo and all > >> > Vista > >> > updates. I'll be curious and anxious to see a fix for this. Frankly, > >> > I'm > >> > about ready to revert back to Windows XP Pro. Aside from application > >> > incompadibilities in Vista (which is severely limiting what I can do > >> > and > >> > support from my Vista machine) I used Hibernation in that OS for years > >> > without issue. I've had nothing but trouble with Hibernation in Vista > >> > on > >> > a > >> > T43 and two T61's. > >> > > >> > For now, I'm going to try unplugging the power source prior to going > >> > into > >> > hibernation mode. What a hokey solution. > >> > > >> > Joel > >> > > >> > > >> > "Ian" wrote: > >> > > >> >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business > >> >> and I > >> >> have installed all the Lenovo and Vista updates. > >> >> > >> >> I fully charged the battery, then put the machine into hibernation and > >> >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, > >> >> the > >> >> battery had lost 15-20% power. However, if I unplugged the AC adapter > >> >> before > >> >> hibernation, the battery didn't drain at all. Lenovo/IBM had already > >> >> replaced > >> >> my battery and motherboard to no avail. I believe Vista was unable to > >> >> shutoff > >> >> the power consumption of all the components. > >> >> > >> >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery > >> >> drain > >> >> issue is real and related to Vista updates. They found out that after > >> >> reinstalling Vista, the battery didn't drain. The drain appeared only > >> >> after > >> >> installing around 19 Vista critical updates. > >> >> > >> >> The repair center admitted that the issue was too complicated for them > >> >> to > >> >> resolve alone. They've already requested assistance from their global > >> >> tech > >> >> support. Does anyone know the cause of battery drain and whether there > >> >> is > >> >> a > >> >> solution or patch somewhere? > >> >> > >> >> > >> >> |
| | #9 (permalink) |
| | Re: Heavy Battery Drain after Hibernation Michael/Joel, By trial and error, I have found out that my Lenovo X61's modem was the culprit quietly draining my battery. Under Control Panel -> Phone and Modem -> Modems tab -> Power Management tab, simply uncheck "Allow this device to wake the computer" should work. Let me know your result. Ian "Ian" wrote: Quote: > Michael, > > The battery drain appeared on both my original 5,400 and the newly acquired > 7,200 rpm drives. I installed Vista (with all the Vista and Lenovo updates) > on both drives in the last couple of days. However, I don't know what I did > RIGHT, I repeatedly hibernate my X61s several times and the battery drain > didn't appear on my 5,400 rpm drive. I didn't have the same luck with my > 7,200 rpm drive though! > > I believe I must have done something different installing my 5,400 rpm drive > than my 7,200 rpm drive. I think it has something to do with which update I > intall first. However, with so many Vista and Lenovo updates, it is unwieldy > for me to figure out. > > > Ian > > > "Michael Walraven" wrote: > Quote: > > Ian, > > My NIC also has a 'allow the computer to turn off this device to save power' > > option. > > > > As I understand, if the computer is on AC power when it is hibernated then > > the clock on the BIOS is set to wake the computer up, for instance at 3AM to > > check for Microsoft updates. If the computer is on battery power when it is > > hibernated, than the BIOS wakeup clock is not set. > > > > It is possible that the two drives have different power management > > capabilities. My drive says it supports D0 and D3 (Power Data property under > > Details Tab in Device manager). > > > > Interesting functionality displayed here, I will be watching for solutions > > or additional understanding of what is going on. > > My laptop is still XP so am not encountering your problem. > > > > Michael > > Vista Home Premium > > > > > > "Ian" <Ian@xxxxxx> wrote in message > > news:2A7B6554-6E5B-4FBF-BAF2-AC6B0EE7648E@xxxxxx Quote: > > > I have no doubt I did use hibernate a dozen times. The battery drain after > > > hibernation is real and repeatable. Both Lenovo Hong Kong and Yamato > > > Laboratory (Lenovo's famous R&D center in Tokyo) have both confirmed the > > > issue. > > > > > > I had reinstalled Vista using the Lenovo recovery discs (2nd revision) 3 > > > times; once on the original 5,400 rpm hard drive and twice on a new 7,200 > > > rpm > > > drive. Every time after I had finished installing Vista, I installed all > > > the > > > Windows and Lenovo updates (using System Update). I was very surprised to > > > find out that the installation on the 5,400 rpm drive resulted in no > > > battery > > > drain. I charged the battery to 100% and waited 8-10 hours several times. > > > However, the twice installations on the 7,200 rpm drive resulted in > > > battery > > > drain! > > > > > > I don't believe the 7,200 rpm has anything to do with the battery drain. I > > > suspect the battery drain has something to do with the priority in > > > installing > > > Windows updates first or Lenovo updates first. > > > > > > Yamato suggested to uncheck the option "Allow this device to wake the > > > computer" on the network card. However, it didn't resolve the issue. > > > > > > I strongly believe one or more buggy drivers are not able to turn off some > > > components after hibernation resulting in the battery drain. > > > > > > Ian > > > > > > > > > "Michael Walraven" wrote: > > > > > >> Vista Home Premium > > >> Normal operation for the start menu power button is sleep, not hibernate, > > >> if > > >> it is plugged in. > > >> > > >> If you have it plugged in, used the power button icon, it will go to > > >> sleep > > >> mode, it will save the system as if it is ready to hibernate (allow > > >> hybrid > > >> sleep turned on), and stay in sleep mode. When you unplug it stays in > > >> sleep > > >> using up the power. > > >> > > >> In the Power options you need to change the way the way the Power buttons > > >> and lid function. > > >> There are options to use when on battery and when plugged in. > > >> > > >> If you want machine to always hibernate when the Start menu power button > > >> is > > >> used for instance you need to set that for both On battery and Plugged in > > >> states. > > >> > > >> Power options, Advanced settings Power buttons and lid. > > >> > > >> You can tell if it actually hibernates or is sleeping. When you start it > > >> back up if it is almost immediately available then it was just sleeping. > > >> If > > >> it shows a busy bar running at the bottom of the screen then it is > > >> restoring > > >> from the hard drive and it did make it to hibernate. > > >> > > >> I am not sure from your post just how you are having the computer > > >> 'hibernate'. With the machine plugged in it will default to sleeping, it > > >> is > > >> tricky to get it to hibernate when plugged in with default settings. > > >> > > >> Michael > > >> > > >> > > >> "JF" <JF@xxxxxx> wrote in message > > >> news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx > > >> > I too have this issue. I just noticed it this morning after seeing it > > >> > happen > > >> > two days in a row. I'm loosing 45% of my battery in 24 hours. I have > > >> > a > > >> > brand new Lenovo T61. I deleted the Lenovo partitions and installed > > >> > Vista > > >> > Enterprise fresh, installed all the latest drivers from Lenovo and all > > >> > Vista > > >> > updates. I'll be curious and anxious to see a fix for this. Frankly, > > >> > I'm > > >> > about ready to revert back to Windows XP Pro. Aside from application > > >> > incompadibilities in Vista (which is severely limiting what I can do > > >> > and > > >> > support from my Vista machine) I used Hibernation in that OS for years > > >> > without issue. I've had nothing but trouble with Hibernation in Vista > > >> > on > > >> > a > > >> > T43 and two T61's. > > >> > > > >> > For now, I'm going to try unplugging the power source prior to going > > >> > into > > >> > hibernation mode. What a hokey solution. > > >> > > > >> > Joel > > >> > > > >> > > > >> > "Ian" wrote: > > >> > > > >> >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business > > >> >> and I > > >> >> have installed all the Lenovo and Vista updates. > > >> >> > > >> >> I fully charged the battery, then put the machine into hibernation and > > >> >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, > > >> >> the > > >> >> battery had lost 15-20% power. However, if I unplugged the AC adapter > > >> >> before > > >> >> hibernation, the battery didn't drain at all. Lenovo/IBM had already > > >> >> replaced > > >> >> my battery and motherboard to no avail. I believe Vista was unable to > > >> >> shutoff > > >> >> the power consumption of all the components. > > >> >> > > >> >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery > > >> >> drain > > >> >> issue is real and related to Vista updates. They found out that after > > >> >> reinstalling Vista, the battery didn't drain. The drain appeared only > > >> >> after > > >> >> installing around 19 Vista critical updates. > > >> >> > > >> >> The repair center admitted that the issue was too complicated for them > > >> >> to > > >> >> resolve alone. They've already requested assistance from their global > > >> >> tech > > >> >> support. Does anyone know the cause of battery drain and whether there > > >> >> is > > >> >> a > > >> >> solution or patch somewhere? > > >> >> > > >> >> > > >> >> |
| | #10 (permalink) |
| | Re: Heavy Battery Drain after Hibernation Hi Ian- Thanks for the tip. This discussion has been most helpful. I just disabled that on the modem. I'll report back after I try hibernating. I was just getting back on this post to ask if you have the built in Bluetooth adapter. But I guess that wouldn't make sense since the radio is powered off, which essentially completely powers off that device, so it doesn't even show up in Device Manager when powered off. By chance, do you know what the power management option is under the Intel Gigabit adapter? It shows "Remove power if cable disconnected". If I recall correctly, this is one of those devices that just worked with the initial install of Vista, then a Windows update pulled down an updated driver, then I went to Intel's web site to get the latest driver. Thanks, Joel "Ian" wrote: Quote: > Michael/Joel, > > By trial and error, I have found out that my Lenovo X61's modem was the > culprit quietly draining my battery. Under Control Panel -> Phone and Modem > -> Modems tab -> Power Management tab, simply uncheck "Allow this device to > wake the computer" should work. Let me know your result. > > Ian > > > "Ian" wrote: > Quote: > > Michael, > > > > The battery drain appeared on both my original 5,400 and the newly acquired > > 7,200 rpm drives. I installed Vista (with all the Vista and Lenovo updates) > > on both drives in the last couple of days. However, I don't know what I did > > RIGHT, I repeatedly hibernate my X61s several times and the battery drain > > didn't appear on my 5,400 rpm drive. I didn't have the same luck with my > > 7,200 rpm drive though! > > > > I believe I must have done something different installing my 5,400 rpm drive > > than my 7,200 rpm drive. I think it has something to do with which update I > > intall first. However, with so many Vista and Lenovo updates, it is unwieldy > > for me to figure out. > > > > > > Ian > > > > > > "Michael Walraven" wrote: > > Quote: > > > Ian, > > > My NIC also has a 'allow the computer to turn off this device to save power' > > > option. > > > > > > As I understand, if the computer is on AC power when it is hibernated then > > > the clock on the BIOS is set to wake the computer up, for instance at 3AM to > > > check for Microsoft updates. If the computer is on battery power when it is > > > hibernated, than the BIOS wakeup clock is not set. > > > > > > It is possible that the two drives have different power management > > > capabilities. My drive says it supports D0 and D3 (Power Data property under > > > Details Tab in Device manager). > > > > > > Interesting functionality displayed here, I will be watching for solutions > > > or additional understanding of what is going on. > > > My laptop is still XP so am not encountering your problem. > > > > > > Michael > > > Vista Home Premium > > > > > > > > > "Ian" <Ian@xxxxxx> wrote in message > > > news:2A7B6554-6E5B-4FBF-BAF2-AC6B0EE7648E@xxxxxx > > > > I have no doubt I did use hibernate a dozen times. The battery drain after > > > > hibernation is real and repeatable. Both Lenovo Hong Kong and Yamato > > > > Laboratory (Lenovo's famous R&D center in Tokyo) have both confirmed the > > > > issue. > > > > > > > > I had reinstalled Vista using the Lenovo recovery discs (2nd revision) 3 > > > > times; once on the original 5,400 rpm hard drive and twice on a new 7,200 > > > > rpm > > > > drive. Every time after I had finished installing Vista, I installed all > > > > the > > > > Windows and Lenovo updates (using System Update). I was very surprised to > > > > find out that the installation on the 5,400 rpm drive resulted in no > > > > battery > > > > drain. I charged the battery to 100% and waited 8-10 hours several times. > > > > However, the twice installations on the 7,200 rpm drive resulted in > > > > battery > > > > drain! > > > > > > > > I don't believe the 7,200 rpm has anything to do with the battery drain. I > > > > suspect the battery drain has something to do with the priority in > > > > installing > > > > Windows updates first or Lenovo updates first. > > > > > > > > Yamato suggested to uncheck the option "Allow this device to wake the > > > > computer" on the network card. However, it didn't resolve the issue. > > > > > > > > I strongly believe one or more buggy drivers are not able to turn off some > > > > components after hibernation resulting in the battery drain. > > > > > > > > Ian > > > > > > > > > > > > "Michael Walraven" wrote: > > > > > > > >> Vista Home Premium > > > >> Normal operation for the start menu power button is sleep, not hibernate, > > > >> if > > > >> it is plugged in. > > > >> > > > >> If you have it plugged in, used the power button icon, it will go to > > > >> sleep > > > >> mode, it will save the system as if it is ready to hibernate (allow > > > >> hybrid > > > >> sleep turned on), and stay in sleep mode. When you unplug it stays in > > > >> sleep > > > >> using up the power. > > > >> > > > >> In the Power options you need to change the way the way the Power buttons > > > >> and lid function. > > > >> There are options to use when on battery and when plugged in. > > > >> > > > >> If you want machine to always hibernate when the Start menu power button > > > >> is > > > >> used for instance you need to set that for both On battery and Plugged in > > > >> states. > > > >> > > > >> Power options, Advanced settings Power buttons and lid. > > > >> > > > >> You can tell if it actually hibernates or is sleeping. When you start it > > > >> back up if it is almost immediately available then it was just sleeping. > > > >> If > > > >> it shows a busy bar running at the bottom of the screen then it is > > > >> restoring > > > >> from the hard drive and it did make it to hibernate. > > > >> > > > >> I am not sure from your post just how you are having the computer > > > >> 'hibernate'. With the machine plugged in it will default to sleeping, it > > > >> is > > > >> tricky to get it to hibernate when plugged in with default settings. > > > >> > > > >> Michael > > > >> > > > >> > > > >> "JF" <JF@xxxxxx> wrote in message > > > >> news:5228F31D-BC17-4424-9818-E6F1FAF8CA76@xxxxxx > > > >> > I too have this issue. I just noticed it this morning after seeing it > > > >> > happen > > > >> > two days in a row. I'm loosing 45% of my battery in 24 hours. I have > > > >> > a > > > >> > brand new Lenovo T61. I deleted the Lenovo partitions and installed > > > >> > Vista > > > >> > Enterprise fresh, installed all the latest drivers from Lenovo and all > > > >> > Vista > > > >> > updates. I'll be curious and anxious to see a fix for this. Frankly, > > > >> > I'm > > > >> > about ready to revert back to Windows XP Pro. Aside from application > > > >> > incompadibilities in Vista (which is severely limiting what I can do > > > >> > and > > > >> > support from my Vista machine) I used Hibernation in that OS for years > > > >> > without issue. I've had nothing but trouble with Hibernation in Vista > > > >> > on > > > >> > a > > > >> > T43 and two T61's. > > > >> > > > > >> > For now, I'm going to try unplugging the power source prior to going > > > >> > into > > > >> > hibernation mode. What a hokey solution. > > > >> > > > > >> > Joel > > > >> > > > > >> > > > > >> > "Ian" wrote: > > > >> > > > > >> >> My machine is a new IBM/Lenovo ultraportable X 61s with Vista Business > > > >> >> and I > > > >> >> have installed all the Lenovo and Vista updates. > > > >> >> > > > >> >> I fully charged the battery, then put the machine into hibernation and > > > >> >> unplugged the AC adapter. After an overnight (8-10 hours) hibernation, > > > >> >> the > > > >> >> battery had lost 15-20% power. However, if I unplugged the AC adapter > > > >> >> before > > > >> >> hibernation, the battery didn't drain at all. Lenovo/IBM had already > > > >> >> replaced > > > >> >> my battery and motherboard to no avail. I believe Vista was unable to > > > >> >> shutoff > > > >> >> the power consumption of all the components. > > > >> >> > > > >> >> At present, Lenovo/IBM Hong Kong Repair Center has confirmed battery > > > >> >> drain > > > >> >> issue is real and related to Vista updates. They found out that after > > > >> >> reinstalling Vista, the battery didn't drain. The drain appeared only > > > >> >> after > > > >> >> installing around 19 Vista critical updates. > > > >> >> > > > >> >> The repair center admitted that the issue was too complicated for them > > > >> >> to > > > >> >> resolve alone. They've already requested assistance from their global > > > >> >> tech > > > >> >> support. Does anyone know the cause of battery drain and whether there > > > >> >> is > > > >> >> a > > > >> >> solution or patch somewhere? > > > >> >> > > > >> >> > > > >> >> |
| 2490 WM5 Recent overnight battery drain ... | Vista hardware & devices | |||
| Laptop battery issue ??battery calibration?? | General Discussion | |||
| Battery continues to drain heavily after my IBM X 61s has hibernated | Vista General | |||
| Aero & laptop battery drain - experiences? | Vista performance & maintenance | |||
| Bitlocker and Sleep/Hibernation or if Battery Runs Down | Vista security | |||
