| | power settings keep changing Hello, I recently discovered hybrid sleep and love it. However, i have a problem. My computer would go to sleep, the power button would flash but nothing i did would wake it up. So i'd have to turn it off and let it resume from hibernation to get it back, which made hybrid sleep useless. Someone offered me some help. They suggested going into device manager, and under keyboard and mouse changing it so that these devices could not wake the pc and then going into my USB root hubs and checking the option to allow vista to shut down the device to save power. After doing this, hyrbid sleep worked and everything in the pc would turn off...my power usage dropped down to 10 watts. however, the changes i made keep getting reset on the USB hubs. So i have to keep going in there and re-checking the box. And when this happens, the pc does not entirely shut off...either a fan or hd is still running, and my power usage is at 50watts. Any ideas why the power settings on the usb devices keeps resetting itself? This is vista ultimate 64bit |
| Power Saving Changing Settings on it's Own. | General Discussion | |||
| Alter (auto) Power settings when plugged in or on Battery Power? | Vista performance & maintenance | |||
Vista power configuration settings are changing on their own! | General Discussion | |||
| Vista power settings - power button functionality | Vista installation & setup | |||
| Changing Power Plans | Vista General | |||
