Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Multiple selections problem
Old 09-23-2007   #1 (permalink)
gg
Hello,
Since few days (I think just after I updated the touchpad driver using
windowsupdate),I cannot make multiple file selections anymore using windows
explorer.The "select all" thing is disabled and I cannot use the ctrl+clic or
shift+clic thing.
How can I restore it?
Old 09-23-2007   #2 (permalink)
peter
Re: Multiple selections problem
revert back to the old touchpad driver...........and in the future do NOT
let Vista upgrade non MS hardware go to the manufaturers website and upgrade
from there.
peter
"gg" <gg@xxxxxx> wrote in message
news:AE81758D-43E6-481E-A6DF-EF3555CEFD16@xxxxxx
Quote:
> Hello,
> windows
> or
> shift+clic thing.
Old 09-24-2007   #3 (permalink)
gg
I managed to get it back,not by uninstalling the driver,but by going on the
desktop in windows explorer and then making a "reinitialiser les
dossiers"(I'm french) in the display tab of the folder
properties(tools/folder properties/display)
> from there.
> peter
Quote:
> > Hello,
> > windows
> > or
> > shift+clic thing.
Font Color Selections Vista mail
windows explorer selections Vista General
How can I make drop Down selections more readable Vista General
Device Manager Selections? Vista hardware & devices
Multiple Selections Vista General
