Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - MSVBVM50.dll Problem
Old 09-24-2007   #1 (permalink)
KillerK
Hi there,
I have just installed a program and everytime I try to run it, I get an
error saying that MSVBVM50.dll is required. I do not know what that is. Is
there anyway I can get the program to run? I have already tried compatibility
mode but that does not seem to help.
Thanks!
Old 09-24-2007   #2 (permalink)
dean-dean
Re: MSVBVM50.dll Problem
If you have access to a computer running Windows XP, you can Copy the file
msvbvm50.dll from C:\WINDOWS\system32\, and Paste it into the same folder as
the program's .exe file that requires it, for example, put it in C:\Program
Files\ MyProgram, if the MyProgram folder contains MyProgram.exe. It
shouldn't have to be put in Vista's C:\WINDOWS\system32\...
If you don't have access to an XP computer, go to
http://support.microsoft.com/kb/172991/EN-US/ , and download
http://activex.microsoft.com/controls/vb5/MSVBVM50.CAB . You can then
extract the file from msvbvm50.cab, and place in the folder as noted above.
"KillerK" <KillerK@xxxxxx> wrote in message
news:CDE1249F-EC51-4788-8BE9-0FAE18A0C6B0@xxxxxx
Quote:
> Hi there,
> compatibility
> Thanks!
Old 10-17-2007   #3 (permalink)
Naturewoman
I am having the same problem. I downloaded the MSVBVM50.dll file but can't
seem to extract it. I don't have a C:\Program
Files\ MyProgram, so tried to extract it into Vista's C:\WINDOWS\system32\,
but a window showed saying "access denied". Any help will be apreciated!
Thanks.
Quote:
> > Hi there,
> > compatibility
> > Thanks!
Old 10-17-2007   #4 (permalink)
dean-dean
Try downloading MSVBVM50.CAB to your desktop, double-click on MSVBVM50.CAB,
then drag msvbvm50.dll out of the MSVBVM50.CAB "folder" to your desktop.
Right-click on msvbvm50.dll, choose Cut, and Paste it into the same folder
as the .exe file (program) that needs it.
"Naturewoman" <Naturewoman@xxxxxx> wrote in message
news:B190EB4F-11D8-4272-90B3-772331B10A8B@xxxxxx
> Thanks.
> "dean-dean" wrote:
>> file
>> as
>> C:\Program
>> above.
Quote:
>> > Hi there,
>> > Is
>> > compatibility
>> > Thanks!
Old 02-10-2009   #5 (permalink)
neu
I am having the same problem. I downloaded the MSVBVM50.dll file but dunno
where to paste it because i am installing a screensaver and it not showing
the target folder.
type of file - application.exe
description - install screensaver
Old 03-25-2009   #6 (permalink)
DLL
RE: MSVBVM50.dll Problem
i have the same problem whith DataStufion program i've downloaded the missing
DLL but still not working
"KillerK" wrote:
Quote:
> Hi there,
> Thanks!
Old 07-16-2009   #7 (permalink)
Jaidee
Thanks very much, your instructions were so clear & easy to follow, it worked
first time !
Quote:
> > Hi there,
> > compatibility
> > Thanks!
Old 3 Weeks Ago   #8 (permalink)
Paulsmt
Even better, copy Both files contained within
to the desktop.
Right click on the MSVBVM50,inf Setup File, and click on Install.
(The Setup File has a picture with one gear, the other file has 2 gears.)
Now any program that needs it should run fine.
Old 3 Weeks Ago   #9 (permalink)
Gerbrand
thanks for the info. it worked!
> "KillerK" <KillerK@newsgroup> wrote in message
> news:CDE1249F-EC51-4788-8BE9-0FAE18A0C6B0@newsgroup
Quote:
> > Hi there,
> > compatibility
> > Thanks!
Old 2 Weeks Ago   #10 (permalink)
fat
"KillerK" wrote:
Quote:
> Hi there,
> Thanks!
msvbvm50.dll problem Vista performance & maintenance
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
