Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - What is minimum and maximum processor state in power management
Old 09-30-2007   #1 (permalink)
Rob
Guest
side question:
Why doesn't Vista help have the answer?
Old 09-30-2007   #2 (permalink)
BillD
Guest
RE: What is minimum and maximum processor state in power management
"Rob" wrote:
> side question:
start -> type: power, and hit Enter key -> change plan settings -> restore
default settings for this plan
start -> type: power, and hit Enter key -> change plan settings -> change
advanced power settings
Old 09-30-2007   #3 (permalink)
Rob
Guest
"BillD" wrote:
Quote:
> "Rob" wrote:
> > side question:
Inadequate answer - RTQ
Obviously, I know how to change it - I need to know what it means.
Old 09-30-2007   #4 (permalink)
Michael
Guest
Re: What is minimum and maximum processor state in power managemen
Carefully examining your question.
On my Vista home premium, the minimum processor state is 0%, the maximum
processor state is 100%. This is for both battery and plugged in.
Michael
"Rob" <robreeve@***comcast.net> wrote in message
news:9A45EF08-3C5E-4231-834B-AF00D5B38A10@xxxxxx
Quote:
> "BillD" wrote:
Quote:
>> "Rob" wrote:
>> > side question:
>> restore
Old 09-30-2007   #5 (permalink)
Paul Smith
Guest
Re: What is minimum and maximum processor state in power management
news:430512BA-6BFB-4A45-9E2A-F7C7C0E7D4CE@xxxxxx
> side question:
It basically refers to the speed of the CPU.
For example, if the maximum is 50% while on battery, the CPU frequency will
be running at 50% normal speed, prolonging battery life at the cost of
performance.
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.dasmirnov.net/blog/
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
Old 10-01-2007   #6 (permalink)
Patrick
Guest
It's the minimum and maximum cpu power available.
If you set the maximum processor state in powermanagement to 50% it should
offer 50% of it's processing power max. when put under load.
With this explanation I guess you understand what the minimum is for?
> side question:
Old 10-07-2007   #7 (permalink)
Shaughn Shea
Guest
http://download.microsoft.com/downlo...cPowerMgmt.doc
Page 8 of that white paper is the start of the section on Processor
Power Mgmt.
Fairly easy read.
Shaughn Shea
Shaughn Shea's Profile: http://forums.techarena.in/member.php?userid=32482
View this thread: http://forums.techarena.in/showthread.php?t=826409
Old 01-23-2008   #8 (permalink)
Newbie
Vista Ultimate
Hello,
I've searched about this and found this page:
"Welcome to The Metaverse : Vista power management & CPU frequency"
In short, Vista is able to vary the processor clock frequency (from 0 Hz to 2.4 GHz, if your maximum processor speed is 2.4 GHz) according to the processor usage. Minimum and maximum processor state control the range within which Vista varies the clock speed.
For example, a minimum of 25% and a maximum of 75% will make Vista vary the speed between 600 MHz (25%) and 1.8 MHz (75%) for a 2.4 MHz processor. "On battery" and "plugged in" is for setting two different ranges for the charging and discharging states.
The point of reducing clock frequency is that, the higher the frequency, the more heat the processor will produce, and the more power it will consume. The lower the frequency, the more time it will take to complete a processing (calculation).
More detailed information with pictures can be found in the link given above.
~ADTC
Minimum Processor State General Discussion
Processor Power Management Vista performance & maintenance
processor power management features have been disabled due to a known firmware error EVENT ID 6 Vista General
Maximum Power Management Under Vista Vista General
Power Management Issues (Underclocked Processor) Vista performance & maintenance
