Can't use single click or do a System Restore
  1. #1
    Sandee Guest
    I've had my new Dell computer with Vista Home Premium for less than a month.
    It seems to me when I first got started I had the option of single clicking
    or double clicking to get programs and windows to open. I chose single click.
    Now I have to dbl click to get anything to open and when I go into folder
    options single click is grayed out so I can't even select it. Why is this?
    I thought I would do a System Restore and maybe I could get the single click
    back but I've tried to do a System Restore twice and both times I got a
    message about an "unspecified error" and was told the restore was not
    successful. The second time I tried it, I used a different restore date but
    got the same message. Any ideas what is going on here? I would really
    appreciate some help.
    Sandee
  2. #2
    DellCA Guest
    Re: Can't use single click or do a System Restore
    Sandee, did you ever get this problem fixed? If you did not, I have a
    few suggestions.
    Go to the Control Panel and open Folder Options. In that, on the
    General tab is where you set the single/double click for icons (which
    it sounds like you have been to already). Try clicking the "Restore
    Defaults" button just before the "Click items as follows" section, then
    try to set the system to use single-click.
    Did you install anything new, or make changes to the configuration at
    about the same time the problem started? If you did, then that is most
    likely the cause of the problem. You might try uninstalling any
    software or patches you loaded just before the problem started to see
    if it goes away.
    The absolute worst case scenario you can back up your data and then
    either use the CTRL+F11 option (just after powering the computer on) to
    reload the Dell factory image, or manually reinstall Vista and the
    drivers.
    Larry
    Dell Customer Advocate
    DellCA
    DellCA's Profile: http://forums.techarena.in/member.php?userid=20193
    View this thread: http://forums.techarena.in/showthread.php?t=826560
  3. #3
    Sandee Guest
    Larry, Thank you so much for answering my post. I did get my problem fixed.
    I finally bit the bullet and called the Dell Customer Support. The tech I
    got spent a lot of time trying to find the problem and he also suggested it
    may have to do with something new I loaded. I wasn't sure what it was so we
    ended up having to start the computer from the beginning. Only instead of
    f11 I think we used f8. Everything has been working fine since then & I'm
    back to the single click.
    Thank you so much for answering me. It is nice to know there are resources
    for people like me that need help once in a while.
    Sandee
    > few suggestions.
    > if it goes away.
    > drivers.
    > Larry
    > DellCA
  4. #4
    DellCA Guest
    > fixed.
    > tech I
    > suggested it
    > so we
    > of
    > I'm
    > resources
    > Sandee
    Glad to hear everything is working again.
    If the problem was not caused by something you installed (software,
    Windows updates, etc) then the only other thing I can think of is
    malware (virus, spyware, etc) as the most likely cause. Although I
    must admit, I've never heard of a virus or spyware messing with the
    single/double click settings. The fact the system restore option failed
    makes me suspect something mangled at least part of the registry but at
    this point it is probably impossible to determine what exactly caused
    it.
    Larry
    DellCA
  5. #5
    Bert Kinney Guest
    Hi Sandee,
    As to the System Restore issue, are here any Norton applications installed?
    If so take a look at the following article.
    "Restoration Incomplete. Your computer cannot be restored . . . "
    http://bertk.mvps.org/html/symantecdoc1.html
    Regards,
    Bert Kinney MS-MVP Shell/User
    Member: http://dts-l.org
    > Sandee
Can't use single click or do a System Restore problems?
How to single click Sandee Vista account administration 5 27 Sep 2007
Single Click Instead Of Double Click Port Admiral Haynes Vista General 2 28 Mar 2007
Single Click? Goldlexus Vista General 3 18 Mar 2007
Enable single click MacroCharlie Vista General 1 27 Feb 2007
hot to change mouse to single click instead of double click to ope joseph bell Vista hardware & devices 1 14 Jun 2006
