| Guest | how to rebuild mediaid.bin In order to restore from a backup the file mediaid.bin must be available in the root of the drive where the backupfolder resides (see KB940263). Does anybody know how to rebuild this file if the original mediaid.bin file is unavailable (for instance, when one moves the backupfolder to another drive, without moving also mediaid.bin) ? Thanks! |
| Guest | RE: how to rebuild mediaid.bin Did you ever find out how to rebuild the Mediaid.bin file? I'm having the same issue (copied backup folder without the Mediaid.bin file). "Zappy" wrote: Quote: > In order to restore from a backup the file mediaid.bin must be available in > the root of the drive where the backupfolder resides (see KB940263). Does > anybody know how to rebuild this file if the original mediaid.bin file is > unavailable (for instance, when one moves the backupfolder to another drive, > without moving also mediaid.bin) ? > Thanks! |
| Guest | RE: how to rebuild mediaid.bin Unfortunately not.... "ASF" wrote: Quote: > Did you ever find out how to rebuild the Mediaid.bin file? I'm having the > same issue (copied backup folder without the Mediaid.bin file). > > "Zappy" wrote: > Quote: > > In order to restore from a backup the file mediaid.bin must be available in > > the root of the drive where the backupfolder resides (see KB940263). Does > > anybody know how to rebuild this file if the original mediaid.bin file is > > unavailable (for instance, when one moves the backupfolder to another drive, > > without moving also mediaid.bin) ? > > Thanks! |
| Procedure to Rebuild MediaID.bin for Restoring Backups | Vista file management | |||
| Mediaid.bin missing or corrupt | General Discussion | |||
| Rebuild the message store of Windows Mail / Rebuild the Windows Mail folder | Vista mail | |||
| Mediaid.bin | Vista General | |||
| Question about MediaID, GlobalCatalog, and GlobalCatalogBackup fil | Vista General | |||
