| | wireless network connection Is ther a way to create two different wireless network connections where one would be used to connect to network at work with specific ip addresses and one would be general where an ip address could be obtained automatically? I realize only one could be enabled at a time. Thank you for any advice you could give. |
| | Re: wireless network connection Hi, Click start, type "network and sharing" and select the entry in the start menu. On the resulting dialog, click the option in the left column to manage wireless networks. Now click the 'add' button to create a second connection that you can customize. You can also set a preference for one over the other. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "JanetP" <JanetP@xxxxxx> wrote in message news:BD32C01D-0725-4D42-805B-3ABA6427768D@xxxxxx Quote: > Is ther a way to create two different wireless network connections where > one > would be used to connect to network at work with specific ip addresses and > one would be general where an ip address could be obtained automatically? > I > realize only one could be enabled at a time. > Thank you for any advice you could give. |
| | Re: wireless network connection Thanks for your advice. I'm sorry, but I do not see an add button. I am running Windows Vista Home Basic. Does that make a difference? Thank you. "Rick Rogers" wrote: Quote: > Hi, > > Click start, type "network and sharing" and select the entry in the start > menu. On the resulting dialog, click the option in the left column to manage > wireless networks. Now click the 'add' button to create a second connection > that you can customize. You can also set a preference for one over the > other. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "JanetP" <JanetP@xxxxxx> wrote in message > news:BD32C01D-0725-4D42-805B-3ABA6427768D@xxxxxx Quote: > > Is ther a way to create two different wireless network connections where > > one > > would be used to connect to network at work with specific ip addresses and > > one would be general where an ip address could be obtained automatically? > > I > > realize only one could be enabled at a time. > > Thank you for any advice you could give. > |
| | Re: wireless network connection Hi, No, it's fine to be running Home Basic. The "add" button should be in the toolbar, signified by a large green "plus" sign after you open the manage wireless networks dialog. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "JanetP" <JanetP@xxxxxx> wrote in message news:928158D4-B99B-43CA-98B0-E99D9E1185D8@xxxxxx Quote: > Thanks for your advice. I'm sorry, but I do not see an add button. I am > running Windows Vista Home Basic. Does that make a difference? > Thank you. > > "Rick Rogers" wrote: > Quote: >> Hi, >> >> Click start, type "network and sharing" and select the entry in the start >> menu. On the resulting dialog, click the option in the left column to >> manage >> wireless networks. Now click the 'add' button to create a second >> connection >> that you can customize. You can also set a preference for one over the >> other. >> >> -- >> Best of Luck, >> >> Rick Rogers, aka "Nutcase" - Microsoft MVP >> http://mvp.support.microsoft.com/ >> Windows help - www.rickrogers.org >> My thoughts http://rick-mvp.blogspot.com >> >> "JanetP" <JanetP@xxxxxx> wrote in message >> news:BD32C01D-0725-4D42-805B-3ABA6427768D@xxxxxx Quote: >> > Is ther a way to create two different wireless network connections >> > where >> > one >> > would be used to connect to network at work with specific ip addresses >> > and >> > one would be general where an ip address could be obtained >> > automatically? >> > I >> > realize only one could be enabled at a time. >> > Thank you for any advice you could give. >> |
| | Re: wireless network connection Thanks, I opened the wrong window. "Rick Rogers" wrote: Quote: > Hi, > > No, it's fine to be running Home Basic. The "add" button should be in the > toolbar, signified by a large green "plus" sign after you open the manage > wireless networks dialog. > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > My thoughts http://rick-mvp.blogspot.com > > "JanetP" <JanetP@xxxxxx> wrote in message > news:928158D4-B99B-43CA-98B0-E99D9E1185D8@xxxxxx Quote: > > Thanks for your advice. I'm sorry, but I do not see an add button. I am > > running Windows Vista Home Basic. Does that make a difference? > > Thank you. > > > > "Rick Rogers" wrote: > > Quote: > >> Hi, > >> > >> Click start, type "network and sharing" and select the entry in the start > >> menu. On the resulting dialog, click the option in the left column to > >> manage > >> wireless networks. Now click the 'add' button to create a second > >> connection > >> that you can customize. You can also set a preference for one over the > >> other. > >> > >> -- > >> Best of Luck, > >> > >> Rick Rogers, aka "Nutcase" - Microsoft MVP > >> http://mvp.support.microsoft.com/ > >> Windows help - www.rickrogers.org > >> My thoughts http://rick-mvp.blogspot.com > >> > >> "JanetP" <JanetP@xxxxxx> wrote in message > >> news:BD32C01D-0725-4D42-805B-3ABA6427768D@xxxxxx > >> > Is ther a way to create two different wireless network connections > >> > where > >> > one > >> > would be used to connect to network at work with specific ip addresses > >> > and > >> > one would be general where an ip address could be obtained > >> > automatically? > >> > I > >> > realize only one could be enabled at a time. > >> > Thank you for any advice you could give. > >> > >> > |
| Wireless Network Connection Problems | Vista networking & sharing | |||
| Losing wireless connection to specific wireless network | Vista networking & sharing | |||
| Wireless Network Connection | Network & Sharing | |||
| Wireless network establishs a public network connection | Vista networking & sharing | |||
| Limited connection with wireless network | Vista hardware & devices | |||
