Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Programs/Applications running
Old 10-15-2007   #1 (permalink)
Mary K
I have programs running all the time on my computer and it is pretty slow.
There are about 25 programs running all the time. Is this normal? Can I stop
these progams from running except for when I need hem?
Old 10-16-2007   #2 (permalink)
Re: Programs/Applications running
Quote  Quote: Originally Posted by Mary K View Post
Hi Mary,
It depends on what programs they are. If they are system programs from Vista, then they will most likely need to be left alone. You can check the Startup programs list to see if there are programs you do not want to run at the startup of Vista. You can just "Disable" them first to test if everything will run ok without them at first, then "Remove" them later if it ok. Method one in this tutorial will show you how.
Startup Programs - Enable or Disable
Old 10-16-2007   #3 (permalink)
Rick Rogers
Hi Mary K,
25 programs or 25 processes? There is a difference. The former would not be
normal, the latter would be depending on system configuration and installed
software.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Mary K" <Mary K@xxxxxx> wrote in message
news:A9E4FA68-F669-4654-B169-8AF9AF7EC8B8@xxxxxx
> stop
Old 10-16-2007   #4 (permalink)
Mary K
Well they are processes, I believe.
"Rick Rogers" wrote:
Quote:
> Hi Mary K,
> software.
> Best of Luck,
> > stop
Old 10-16-2007   #5 (permalink)
Hi Mary,
If you are looking at them in Task Manager in the Processes tab, then 25 is not bad at all. I have 39 processes runnning at all times usually. You can look at the Startup Programs list from my eariler post to see if you want to trim any of those programs you do not need.
Running DOS based applications with full screen Vista performance & maintenance
Can Vista Gadgets Get Info about Applications Currently Running ? Vista General
applications Running very slowly in vista Vista performance & maintenance
iis 7.0 - applications running under dot net framework 1.1 Vista installation & setup
