Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Printing problem with minolta 2300 DL
Closed Thread
Thread Tools Display Modes
Old 10-21-2007   #1 (permalink)
tlshaw
Guest
I recently purchased a laptop with Vista Home Premium. The printer is
connected to the wireless hub and works fine with our 2 laptops running XP. I
followed Konica's instructions for installing the printer. I can print a test
page fine. Also, in I go into printer properties as an administrator I can
print a test page. However, I can't print from any applications such as word.
I have deleted and reinstalled the printer, again following all the
instructions and using the driver for Vista.
Old 10-21-2007   #2 (permalink)
Cari \(MS-MVP\)
Guest
Re: Printing problem with minolta 2300 DL
After you have installed the printer and set it as default, open Word, open
a document, then File, Print, and ensure that the printer selected is the
Konica.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"tlshaw" <tlshaw@xxxxxx> wrote in message
news:C290EAB1-37D1-4E6C-8084-5AC8ACE709CC@xxxxxx
> XP. I
> test
> word.
Old 10-22-2007   #3 (permalink)
tlshaw
Guest
When I tried to print, I used the print option, not quick print, and made
sure the konica was set as the printer. I tried this several times with no
success.
> Konica.
> Cari (MS-MVP)
> > XP. I
> > test
> > word.
Old 10-23-2007   #4 (permalink)
Cari \(MS-MVP\)
Guest
Did you try reinstalling Word (or Office)?
Cari (MS-MVP)
news:F3EE2266-DD46-44DD-8D8C-F8B280B13905@xxxxxx
> success.
>> open
>> Konica.
>> Cari (MS-MVP)
>> > XP. I
>> > a
>> > test
>> > can
>> > word.
Old 10-23-2007   #5 (permalink)
tlshaw
Guest
I can't print from any program. I have tried printing emails, a document in
Adobe, and a web page. All with no success. The printer icon will show a
document pending, but then goes away, with nothing happening.
> Cari (MS-MVP)
> > success.
> >> open
> >> Konica.
> >> Cari (MS-MVP)
> >> > XP. I
> >> > a
> >> > test
> >> > can
> >> > word.
Old 10-23-2007   #6 (permalink)
tlshaw
Guest
I am posting this in hopes it will help other people with similar problems. I
checked the Konica website and read the suggestion that the UAC was the
problem. I turned off the UAC and now it works fine. Why didn't Microsoft
know this?
> > Cari (MS-MVP)
> > > success.
> > >> open
> > >> Konica.
> > >> Cari (MS-MVP)
> > >> > XP. I
> > >> > a
> > >> > test
> > >> > can
> > >> > word.
Old 10-24-2007   #7 (permalink)
googsunil
Guest
Can you give me the instructions you used to configure vista to work
with minolta 2300DL?
Old 10-25-2007   #8 (permalink)
tlshaw
Guest
Sure. Click on Start. Then double click on User Accounts and Family Safety.
You will then see a list of options under Make changes to your user account.
The last one is Turn User Account Control on or off. Uncheck the box by Use
User Account Control and click ok. You will probably get a warning message,
but just click on ok.
Hope this helps.
Old 11-18-2007   #9 (permalink)
dugandean
Guest
On Oct 21, 8:36�pm, "Cari \(MS-MVP\)" <NewsGro...@xxxxxx>
> Konica.
> Cari (MS-MVP)
> Windows Technologies - Printing & Imaginghttp://www.coribright.com/windows
> "tlshaw" <tls...@xxxxxx> wrote in message
> news:C290EAB1-37D1-4E6C-8084-5AC8ACE709CC@xxxxxx>I recently purchased a laptop with Vista Home Premium. The printer is
> > XP. I
> > test
> > word.
Closed Thread
Display Modes
Vista 64 driver for a Minolta Magicolor 2300 dl Mikie Vista General 6 06-16-2008 10:01 AM
Minolta Magicolor 2300 DL Printer Driver Kent_Diego Drivers 7 04-16-2008 11:42 PM
Minolta Magicolor 2300 DL with Vista x64? Kent_Diego Vista print fax & scan 3 04-16-2008 11:40 PM
Konica Minolta 2400W printer problem Weird Harold Vista hardware & devices 3 10-15-2007 12:17 AM
HP LaserJet 2300 Printer Brian Bradley Vista General 0 08-04-2006 02:23 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
