Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Printer Setup Problem
Old 10-27-2007   #1 (permalink)
John
I am having trouble setting up my printer, a HP DeskJet 5550, on my new
Vista machine. It runs through a Linksys WPS54G printer server. My old XP
machine, sitting right here next to me, prints through it with no
difficulties. I've tried everything I can think of. Can someone help me?
Old 10-28-2007   #2 (permalink)
Malke
Re: Printer Setup Problem
> XP machine, sitting right here next to me, prints through it with no
What does "everything I can think of" include?
General directions:
1. Install Vista drivers for the print server (get from print server
mftr's website) on the Vista computer.
2. Install Vista drivers for the printer (get from printer mftr.'s
Does your print server support Vista? If not, there's your answer. If it
is supposed to, what does Linksys tech support say?
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 10-28-2007   #3 (permalink)
John
I've tried setting it up using the installation disks that came with the
print server and manually setting up a TCP/IP port (duplicating my XP
settings). As for it being "Vista ready", I have plugged the printer
directly into the computer (USB) and Vista installed the drivers and had me
printing in less than 2 minutes!
"Malke" <notreally@xxxxxx> wrote in message
news:u%23LAF0VGIHA.748@xxxxxx
> General directions:
> Malke
> "Don't Panic!"
Old 10-28-2007   #4 (permalink)
Malke
> me printing in less than 2 minutes!
Since the printer works when directly connected to the computer, you
know the issue is with the print server. Go to Linksys' website for the
latest drivers for the print server and download them. Also download any
firmware updates for the print server. Uninstall the print server
drivers you installed on the Vista machine first.
Apply the firmware update, if any.
Install the new drivers for the print server.
If still no joy, contact Linksys tech support for help with the print
server.
Malke
"Don't Panic!"
Old 10-29-2007   #5 (permalink)
John
I'll try that as soon as I get home tomorrow night and will report back.
Thanks.
news:%23fpvmVWGIHA.700@xxxxxx
> Since the printer works when directly connected to the computer, you know
> the issue is with the print server. Go to Linksys' website for the latest
> drivers for the print server and download them. Also download any firmware
> updates for the print server. Uninstall the print server drivers you
> server.
> Malke
> "Don't Panic!"
Old 10-30-2007   #6 (permalink)
John
Tried everything you recommended. Still no go. I'm at a dead end. The
printer works fine when plugged directly into the Vista machine.
> server.
> Malke
> "Don't Panic!"
Old 10-30-2007   #7 (permalink)
Malke
Then I'm sorry, but aside from contacting Linksys tech support I don't
have any other suggestions.
Malke
"Don't Panic!"
Old 10-30-2007   #8 (permalink)
John
I do appreciate your help. I'm about to contact Linksys's support and see if
they can help. Thanks!
news:OJS9iGxGIHA.3980@xxxxxx
> Malke
> "Don't Panic!"
Old 10-31-2007   #9 (permalink)
Vista Ultimate x64
If this is for the wired Linksys print server. Then it does support Vista 64.
Not 100% about Vista 32 as that's is not the OS I'm running.
I brought it to go between a Vista 64 and a XP machine. The XP machine ran from it fine but the 64 bit didn't. Gave me some sort of error message in the late stages of installing, I think it was I had to pair the computer to the printer through the server.
In contacting Linksys I was told that they may release a 64 bit driver but got given no date, just a maybe. I pressed for a estimate to no avail.
So now we have two computers, two USB cables, one printer and a manual swap over of the connected lead system going on. Most annoy as I have £40 odd quid of box sitting next to me gathering dust.
I'm keeping it on the off chance there will be a driver as they erred towards one coming out but didn't say where.
David
Want to setup Printer Sharing, please help Network & Sharing
printer setup Virtual PC
Help with Bluetooth Printer Setup Vista print fax & scan
Printer setup error Vista print fax & scan
Printer Setup Trouble Vista print fax & scan
