Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - HP L7580 Printer Fax and Scanner Driver Installation Problems
Old 11-04-2007   #11 (permalink)
mmeche
Re: HP L7580 Printer Fax and Scanner Driver Installation Problems
I will keep looking for a solution. Even though I don't get full
functionality it is still a good printer. I would hope that HP will
eventually get their laptops to work with their printers. Time will probably
solve this issue. Thanks for all of the assistance.
mmeche
"huwyngr" wrote:
Quote:
> In article <8A6C0E97-C5E0-4CB9-B54D-00AC759976A5@xxxxxx>, Mmeche
> wrote:
Quote:
> > it installs the printer driver right away
> > but not the fax driver.
> Fortunately for me, but not for you, my fax is a freestanding unit so I
> don't have to worry about more than the incoming spam! I wish I could
> help on that but it's not my area of knowledge or experience.
> Have you checked the HP website for support on the problem? It may be
> something quite simple or it may be not possible with your version of
> VISTA -- I just don't know.
Old 11-04-2007   #12 (permalink)
huwyngr
Keep up the pressure on HP since their support services are usually
good. But part of the problem I think is in VISTA and part in the
version of VISTA that you have, if I remember correctly that you have a
Home version of VISTA.
HP Officejet Pro L7580 Printer Vista mail
HP L7580 Printer failure Vista print fax & scan
How do I install a scanner driver for a printer? Vista print fax & scan
HP Printer / Scanner driver availability question Vista print fax & scan
Windows Vista embeded (scanner/printer/digital camera) driver list Vista print fax & scan
