| | Vista print spooler problem A customer brought her Lenovo laptop w/VHP in because the print spooler crashes whenever she clicks on Add Printer. She had clicked it because her printer had disappeared from the system. The event log shows event ID 1033, "the print spooler cannot start because the printerBusEnumerator could not start. Error code 0x80070006. This can occur because of system instability or a lack of system resources." I can restart the spooler service after this error, but no printers appear in the printer window. She previously had an HP OJ 7110 and the Microsoft xps writer in the folder. If I try to go into printer server properties, this also causes the spooler to crash, with the same error code. I followed the instructions from here... http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm .... but they didn't help. Anyone know of a fix for this? |
| | Re: Vista print spooler problem seem to be two links: heres another one for you: http://groups.google.com/group/micro...2501c2ed3e37bf On Dec 27 2007, 4:11*pm, wyocowboy <wyocow...@xxxxxx> wrote: Quote: > "jimjamsel...@xxxxxx" wrote: Quote: > > On Nov 14, 11:44 pm, wyocowboy <wyocow...@xxxxxx> > > wrote: Quote: > > > A customer brought her Lenovo laptop w/VHP in because the print spooler > > > crashes whenever she clicks on Add Printer. She had clicked it becauseher > > > printer had disappeared from the system. Quote: Quote: > > > The event log shows event ID 1033, "the print spooler cannot start because > > > the printerBusEnumerator could not start. Error code 0x80070006. This can > > > occur because of system instability or a lack of system resources." Quote: Quote: > > > I can restart the spooler service after this error, but no printers appear > > > in the printer window. She previously had an HP OJ 7110 and the Microsoft xps > > > writer in the folder. Quote: Quote: > > > If I try to go into printer server properties, this also causes the spooler > > > to crash, with the same error code. Quote: Quote: > > > I followed the instructions from here...http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm Quote: Quote: > > > ... but they didn't help. Quote: Quote: > > > Anyone know of a fix for this? Quote: > > Sorry to be a pain, this error just happened to me but I've managed > > to > > fix it - *do you still need the instructions? > I could use them for next time, yes... > > > > - Hide quoted text - > > - Show quoted text -- Hide quoted text - > > - Show quoted text - |
| | Re: Vista print spooler problem On Jan 21, 10:42*pm, jimjamsel...@xxxxxx wrote: Quote: > seem to be two links: heres another one for you:http://groups.google.com/group/micro....vista.print_f... > > On Dec 27 2007, 4:11*pm, wyocowboy > > > > <wyocow...@xxxxxx> wrote: Quote: > > "jimjamsel...@xxxxxx" wrote: Quote: > > > On Nov 14, 11:44 pm, wyocowboy <wyocow...@xxxxxx> > > > wrote: > > > > A customer brought her Lenovo laptop w/VHP in because the printspooler > > > > crashes whenever she clicks on Add Printer. She had clicked it because her > > > > printer had disappeared from the system. Quote: Quote: > > > > The event log shows event ID 1033, "the printspoolercannot start because > > > > the printerBusEnumerator could not start. Error code 0x80070006. This can > > > > occur because of system instability or a lack of system resources." Quote: Quote: > > > > I can restart thespoolerservice after this error, but no printers appear > > > > in the printer window. She previously had an HP OJ 7110 and the Microsoft xps > > > > writer in the folder. Quote: Quote: > > > > If I try to go into printer server properties, this also causes thespooler > > > > to crash, with the same error code. Quote: Quote: > > > > I followed the instructions from here...http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm Quote: Quote: > > > > ... but they didn't help. Quote: Quote: > > > > Anyone know of a fix for this? Quote: Quote: > > > Sorry to be a pain, this error just happened to me but I've managed > > > to > > > fix it - *do you still need the instructions? Quote: > > I could use them for next time, yes... Quote: > > - Hide quoted text - Quote: > > - Show quoted text -- Hide quoted text - Quote: > > - Show quoted text -- Hide quoted text - > - Show quoted text - PrinterBusEnumerator entry in the System\CurrentControlSet\Enum\UMB \UMB\1&841921d&0&PrinterBusEnemerator. Either this entry is corrupt or missing or the required drivers are not installed. As this is not a plug and play device the drivers are not installed on a restart or through device manager by clicking update hardware. To correct this issue: Start, [RIGHT CLICK] Computer, Properties, Device Manager [CONTINUE], From Menu bar, choose VIEW, Show Hidden devices.Then Devices by connection. Scroll to System Devices, and then UMBus Enumerator. Check that there are two others. Do not delete. If there are three: Right click on the bottom one. Choose properties. Under details tab choose under the property combo box DEVICE CLASS GUID. Confirm GUID matches that under the DRIVER entry in the registry as above. Right click and uninstall (you will reinstall in a second) If the GUID does not match, choose the other two until you find the correct one. Choose ACTION, ADD LEGACY HARDWARE Choose NEXT Choose INSTALL THE HARDWARE THAT I MANUALLY SELECT.. (ADVANCED) Choose SYSTEM DEVICES, then MICROSOFT and UMBUS Enumerator Restart, a system install will begin on restart of various associated drivers. When complete, restart again and check service is running. Help this helps, jimjamsellis |
| | Re: Vista print spooler problem jimjamsellis@xxxxxx;3512270 Wrote: Quote: [color=blue] > On Jan 21, 10:42*pm, jimjamsel...@xxxxxx wrote: > Scroll to System Devices, and then UMBus Enumerator. Check that there > are two others. steps posted by mister jimjamsellis to try and resolve the problem but stopped at this step... UMBus Enumerator does not exist/is not installed -- Declan ------------------------------------------------------------------------ Declan's Profile: http://forums.techarena.in/member.php?userid=48174 View this thread: http://forums.techarena.in/showthread.php?t=852690 http://forums.techarena.in |
| Windows vista print spooler problem. | Vista General | |||
| Vista 32 bit Print spooler problem? | Vista print fax & scan | |||
| print spooler problem with Vista | Vista General | |||
| Vista print spooler problem | Vista General | |||
| RE: Vista print spooler problem with MC2400W and MC2430DL printers | Vista print fax & scan | |||
