| | Vista - Lexmark X8350 and Vista Home Premium 32-bit |
| 11-19-2007 | #1 |
| | Lexmark X8350 and Vista Home Premium 32-bit My Lexmark X8350 work fine for most functions but when I access the Productivity Suite "Manage Documents" or "Manage Fax History or all-In-One Fax Settings" I get and error message "The program you are trying to run is missing. Please re-install your software." I have installed the latest Lexmark driver cjr8300N but the problem still exists. Any suggestions? |
| My System Specs |
| 11-19-2007 | #2 |
| | Re: Lexmark X8350 and Vista Home Premium 32-bit I set up this AIO for a friend last month with a new Vista machine. I don't recall the software other than the driver stuff installing. I believe you need to go to the original CD and install the OCR and other software separately. Last time I checked the Lexmark site no Vista specific software existed. rnrdude wrote: Quote: > My Lexmark X8350 work fine for most functions but when I access the > Productivity Suite "Manage Documents" or "Manage Fax History or all-In-One > Fax Settings" I get and error message "The program you are trying to run is > missing. Please re-install your software." I have installed the latest > Lexmark driver cjr8300N but the problem still exists. > > Any suggestions? |
| My System Specs |
| 11-29-2007 | #3 |
| | Re: Lexmark X8350 and Vista Home Premium 32-bit When I installed my Lexmark P6250 to Vista, the Lexmark download site explained that Vista would be providing the software for my All-In-One. There were no drivers available for Vista. The only problem is that with Vista I lost over half of the functionality that I had with Lexmark software on my old O/S. For example, I know I could get some pretty dense scan densities using the old software, but 300 dpi is a good as it gets with Vista. There is nothing Vista has that is an improvement over Lexmark and much is left out. Now, I don't know if any of this fits your printer situation, but I can't help but wonder if some are installing XP drivers, thinking they will work for Vista. Bottom line, this is not a good situation we are in as Lexmark users under Vista. John "bjr" <bj-nospam@xxxxxx> wrote in message news:OmuAfSrKIHA.4880@xxxxxx Quote: >I set up this AIO for a friend last month with a new Vista machine. I don't >recall the software other than the driver stuff installing. I believe you >need to go to the original CD and install the OCR and other software >separately. Last time I checked the Lexmark site no Vista specific software >existed. > > rnrdude wrote: Quote: >> My Lexmark X8350 work fine for most functions but when I access the >> Productivity Suite "Manage Documents" or "Manage Fax History or >> all-In-One Fax Settings" I get and error message "The program you are >> trying to run is missing. Please re-install your software." I have >> installed the latest Lexmark driver cjr8300N but the problem still >> exists. >> >> Any suggestions? |
| My System Specs |
| 11-30-2007 | #4 |
| | Re: Lexmark X8350 and Vista Home Premium 32-bit As I indicated in my original post, I downloaded and installed cjr8300N.exe that Lexmark indicated was the Vista driver for my X8350 printer. That driver did not fix the problem that I indicated in my original post. Thanks for the response and I agree that both Lexmark and Microsoft need to start talking to each other. "John" wrote: Quote: > When I installed my Lexmark P6250 to Vista, the Lexmark download site > explained that Vista would be providing the software for my All-In-One. > There were no drivers available for Vista. The only problem is that with > Vista I lost over half of the functionality that I had with Lexmark software > on my old O/S. For example, I know I could get some pretty dense scan > densities using the old software, but 300 dpi is a good as it gets with > Vista. There is nothing Vista has that is an improvement over Lexmark and > much is left out. > > Now, I don't know if any of this fits your printer situation, but I can't > help but wonder if some are installing XP drivers, thinking they will work > for Vista. > > Bottom line, this is not a good situation we are in as Lexmark users under > Vista. > > John > > > "bjr" <bj-nospam@xxxxxx> wrote in message > news:OmuAfSrKIHA.4880@xxxxxx Quote: > >I set up this AIO for a friend last month with a new Vista machine. I don't > >recall the software other than the driver stuff installing. I believe you > >need to go to the original CD and install the OCR and other software > >separately. Last time I checked the Lexmark site no Vista specific software > >existed. > > > > rnrdude wrote: Quote: > >> My Lexmark X8350 work fine for most functions but when I access the > >> Productivity Suite "Manage Documents" or "Manage Fax History or > >> all-In-One Fax Settings" I get and error message "The program you are > >> trying to run is missing. Please re-install your software." I have > >> installed the latest Lexmark driver cjr8300N but the problem still > >> exists. > >> > >> Any suggestions? > |
| My System Specs |
| Similar Threads for: Lexmark X8350 and Vista Home Premium 32-bit | ||||
| LEXMARK X75 PrinTrio FOR VISTA 64 HOME | Drivers | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Lexmark x1185 install on Vista Home Basic | Vista print fax & scan | |||
| Any Known Issues with Lexmark X8350 All-in-One | Vista print fax & scan | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
