| | Re: ie 7 printing problems Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via crosspost. -- ~Robear Dyer (PA Bear) MS MVP-Windows (IE, OE, Security, Shell/User) AumHa VSOP & Admin http://aumha.net DTS-L http://dts-l.org/ Freddy wrote: Quote: > I am running vista 64-bit Ultimate > I use an HP Deskjet 460c for travel printer > > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, I > get > the the following popup window message: > > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or > Internet address is correct." > > What is going on and how do I fix this. > > Thanks in advance for your help. |
| | Re: ie 7 printing problems "PA Bear" wrote: Quote: > Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via > crosspost. > -- > ~Robear Dyer (PA Bear) > MS MVP-Windows (IE, OE, Security, Shell/User) > AumHa VSOP & Admin http://aumha.net > DTS-L http://dts-l.org/ > > Freddy wrote: Quote: > > I am running vista 64-bit Ultimate > > I use an HP Deskjet 460c for travel printer > > > > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, I > > get > > the the following popup window message: > > > > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or > > Internet address is correct." > > > > What is going on and how do I fix this. > > > > Thanks in advance for your help. > Freddy, I just went thtough same problem. I had to contact Canon for instructions to activate a new driver. It was pretty easy. You can probably find the info on HO's website, if not contact them. Hope this helps. Joe Fitz |
| | Re: ie 7 printing problems After exhaustive research, it was determined that this is a ie7 problem caused by the hp driver not being "authenticated" by the server. Microsoft has opened a case on it and will correct "within a month or two". Work around is to shut protection off, then print page (from toolbar). Or copy and paste, then print from that application instead. Thought people would like to know. Thanks for the help. Freddy "Joe Fitz" <JoeFitz@xxxxxx> wrote in message news:6A8743C5-6FBA-4BC7-A94A-41733AB59A00@xxxxxx Quote: > > > "PA Bear" wrote: > Quote: >> Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via >> crosspost. >> -- >> ~Robear Dyer (PA Bear) >> MS MVP-Windows (IE, OE, Security, Shell/User) >> AumHa VSOP & Admin http://aumha.net >> DTS-L http://dts-l.org/ >> >> Freddy wrote: Quote: >> > I am running vista 64-bit Ultimate >> > I use an HP Deskjet 460c for travel printer >> > >> > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, >> > I >> > get >> > the the following popup window message: >> > >> > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or >> > Internet address is correct." >> > >> > What is going on and how do I fix this. >> > >> > Thanks in advance for your help. >> Freddy, I just went thtough same problem. I had to contact Canon for >> instructions to activate a new driver. It was pretty easy. You can >> probably find the info on HO's website, if not contact them. Hope this >> helps. Joe Fitz |
| | Re: ie 7 printing problems Why are you installing HP drivers from Microsoft? Freddy wrote: Quote: > After exhaustive research, it was determined that this is a ie7 problem > caused by the hp driver not being "authenticated" by the server. > Microsoft > has opened a case on it and will correct "within a month or two". > > Work around is to shut protection off, then print page (from toolbar). Or > copy and paste, then print from that application instead. > > Thought people would like to know. > > Thanks for the help. > > Joe Fitz wrote: Quote: Quote: >>> Freddy, I just went thtough same problem. I had to contact Canon for >>> instructions to activate a new driver. It was pretty easy. You can >>> probably find the info on HO's website, if not contact them. Hope this >>> helps. Joe Fitz >> "PA Bear" wrote: Quote: >>> Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via >>> crosspost. >>> -- >>> Freddy wrote: >>>> I am running vista 64-bit Ultimate >>>> I use an HP Deskjet 460c for travel printer >>>> >>>> When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, >>>> I get the the following popup window message: >>>> >>>> "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or >>>> Internet address is correct." |
| | Re: ie 7 printing problems Thanks for the tip! I had the same IE 7 printing problem after installing the latest Vista updates. I turned Protected Mode off and I can print. I wonder when Microsoft is going to fix this!!??! Pretty soon you'll have to disconnect your PC from the Internet so you can print! -- Sign me "Frustrated" "Freddy" wrote: Quote: > After exhaustive research, it was determined that this is a ie7 problem > caused by the hp driver not being "authenticated" by the server. Microsoft > has opened a case on it and will correct "within a month or two". > > Work around is to shut protection off, then print page (from toolbar). Or > copy and paste, then print from that application instead. > > Thought people would like to know. > > Thanks for the help. > > Freddy > > > "Joe Fitz" <JoeFitz@xxxxxx> wrote in message > news:6A8743C5-6FBA-4BC7-A94A-41733AB59A00@xxxxxx Quote: > > > > > > "PA Bear" wrote: > > Quote: > >> Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via > >> crosspost. > >> -- > >> ~Robear Dyer (PA Bear) > >> MS MVP-Windows (IE, OE, Security, Shell/User) > >> AumHa VSOP & Admin http://aumha.net > >> DTS-L http://dts-l.org/ > >> > >> Freddy wrote: > >> > I am running vista 64-bit Ultimate > >> > I use an HP Deskjet 460c for travel printer > >> > > >> > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, > >> > I > >> > get > >> > the the following popup window message: > >> > > >> > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or > >> > Internet address is correct." > >> > > >> > What is going on and how do I fix this. > >> > > >> > Thanks in advance for your help. > >> > >> Freddy, I just went thtough same problem. I had to contact Canon for > >> instructions to activate a new driver. It was pretty easy. You can > >> probably find the info on HO's website, if not contact them. Hope this > >> helps. Joe Fitz > |
| | #6 (permalink) |
| | Re: ie 7 printing problems HP does not make drivers for my all-in-one for Vista. After many "fits" I found a HP tech rep that know of the problem and she had me install the HP990C driver. after a few adjustment in the default settings it works fine. "ValcomTech" wrote: Quote: > Thanks for the tip! I had the same IE 7 printing problem after installing > the latest Vista updates. I turned Protected Mode off and I can print. I > wonder when Microsoft is going to fix this!!??! Pretty soon you'll have to > disconnect your PC from the Internet so you can print! > -- > > Sign me "Frustrated" > > > "Freddy" wrote: > Quote: > > After exhaustive research, it was determined that this is a ie7 problem > > caused by the hp driver not being "authenticated" by the server. Microsoft > > has opened a case on it and will correct "within a month or two". > > > > Work around is to shut protection off, then print page (from toolbar). Or > > copy and paste, then print from that application instead. > > > > Thought people would like to know. > > > > Thanks for the help. > > > > Freddy > > > > > > "Joe Fitz" <JoeFitz@xxxxxx> wrote in message > > news:6A8743C5-6FBA-4BC7-A94A-41733AB59A00@xxxxxx Quote: > > > > > > > > > "PA Bear" wrote: > > > > > >> Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via > > >> crosspost. > > >> -- > > >> ~Robear Dyer (PA Bear) > > >> MS MVP-Windows (IE, OE, Security, Shell/User) > > >> AumHa VSOP & Admin http://aumha.net > > >> DTS-L http://dts-l.org/ > > >> > > >> Freddy wrote: > > >> > I am running vista 64-bit Ultimate > > >> > I use an HP Deskjet 460c for travel printer > > >> > > > >> > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, > > >> > I > > >> > get > > >> > the the following popup window message: > > >> > > > >> > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or > > >> > Internet address is correct." > > >> > > > >> > What is going on and how do I fix this. > > >> > > > >> > Thanks in advance for your help. > > >> > > >> Freddy, I just went thtough same problem. I had to contact Canon for > > >> instructions to activate a new driver. It was pretty easy. You can > > >> probably find the info on HO's website, if not contact them. Hope this > > >> helps. Joe Fitz > > |
| | #7 (permalink) |
| | Re: ie 7 printing problems Thanks for the info Dan. I downloaded and installed a new driver (7-10-2007) from HP for my HP LJ 4000, but it did not fix the problem. -- Still Frustrated. "dan" wrote: Quote: > HP does not make drivers for my all-in-one for Vista. After many "fits" I > found a HP tech rep that know of the problem and she had me install the > HP990C driver. after a few adjustment in the default settings it works fine. > > > > "ValcomTech" wrote: > Quote: > > Thanks for the tip! I had the same IE 7 printing problem after installing > > the latest Vista updates. I turned Protected Mode off and I can print. I > > wonder when Microsoft is going to fix this!!??! Pretty soon you'll have to > > disconnect your PC from the Internet so you can print! > > -- > > > > Sign me "Frustrated" > > > > > > "Freddy" wrote: > > Quote: > > > After exhaustive research, it was determined that this is a ie7 problem > > > caused by the hp driver not being "authenticated" by the server. Microsoft > > > has opened a case on it and will correct "within a month or two". > > > > > > Work around is to shut protection off, then print page (from toolbar). Or > > > copy and paste, then print from that application instead. > > > > > > Thought people would like to know. > > > > > > Thanks for the help. > > > > > > Freddy > > > > > > > > > "Joe Fitz" <JoeFitz@xxxxxx> wrote in message > > > news:6A8743C5-6FBA-4BC7-A94A-41733AB59A00@xxxxxx > > > > > > > > > > > > "PA Bear" wrote: > > > > > > > >> Forwarded to microsoft.public.windows.vista.print_fax_scan newsgroup via > > > >> crosspost. > > > >> -- > > > >> ~Robear Dyer (PA Bear) > > > >> MS MVP-Windows (IE, OE, Security, Shell/User) > > > >> AumHa VSOP & Admin http://aumha.net > > > >> DTS-L http://dts-l.org/ > > > >> > > > >> Freddy wrote: > > > >> > I am running vista 64-bit Ultimate > > > >> > I use an HP Deskjet 460c for travel printer > > > >> > > > > >> > When using 64-bit ie7 or 32-bit ie7 and try to print from ie7 toolbar, > > > >> > I > > > >> > get > > > >> > the the following popup window message: > > > >> > > > > >> > "Cannot find 'file:///C:/Tmp/Low/C100VT1S.htm'. Make sure the path or > > > >> > Internet address is correct." > > > >> > > > > >> > What is going on and how do I fix this. > > > >> > > > > >> > Thanks in advance for your help. > > > >> > > > >> Freddy, I just went thtough same problem. I had to contact Canon for > > > >> instructions to activate a new driver. It was pretty easy. You can > > > >> probably find the info on HO's website, if not contact them. Hope this > > > >> helps. Joe Fitz > > > > > > |
| Printing problems | Vista print fax & scan | |||
| Re: still problems with printing in ie7 | Vista print fax & scan | |||
| Printing Problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
| printing problems | Vista print fax & scan | |||
