| Guest | Vista network printing problems - home pc deletes print job We have a little network where I work (F.D.) and we can't get the host PC (which is running XP home) to let us print to it. I have read a number of posts, and have done the following (below my post). My laptop (running Vista) can see the host PC. When I print to the host, the printer spooler sees the job, then the host pc's print spooler deletes the job (I see it happen in the Status tab. Any ideas? Thanks, Ken Try this Make sure both computers are in same workgroup, then... 1.) Verify that File and print sharing is turned on and properly configured on the XP machine. 2.) Locate and notate the Win XP computer name (i.e. "Desktop") (Found in System Properties in the Computer Name tab) 3.) Locate and notate the printer share name on the XP computer (i.e. "Printer") (Found under the Sharing tab on the Printer Properties page) 4.) On the Vista machine launch the "Add a Printer" wizard 5.) Choose "Add a local printer" 6.) Select "Create a new port" radio button and choose "Local Port" from the drop down menu 7.) Press Next 8.) In the "Enter Port Name:" box enter the following: \\Desktop \Printer where "Desktop" = the computer name from step 2 and "Printer" = the printer share name from step 3. 9.) Select the Printer driver from the list provided or use the "Have Disk" button to install the correct Vista driver if it is not in the built- in list. It is critical that the driver you use is Vista compatible. 10.) Press next 11.) Give the printer a distinct name and choose whether to set as the default. 12.) Press Next 13.) Print a test page to verify functionality. 14.) Press Finish "Malke" <notrea...@xxxxxx> wrote in message |
| Problems printing to a network Vista home premium computer | Vista print fax & scan | |||
| XP-Vista Home Network; Printing Prefrences Unavailable | Vista networking & sharing | |||
| Vista deletes print jobs from queue | Vista General | |||
| Vista Home Premium on XP Pro network won't print | Vista networking & sharing | |||
| Re: Printing, IE 7, Vista Ultimate home network | Vista print fax & scan | |||
