Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Re: still problems with printing in ie7
Old 12-08-2007   #1 (permalink)
PA Bear
Crossposted to microsoft.public.windows.vista.print_fax_scan newsgroup.
Did you install any of the Yahoo-branded crap? Did you install McAfee
Security Center?
If you make IE the default at Set Program Access and Defaults, does the
setting "stick" when you reboot?
~PA Bear
tif wrote:
Quote:
> I have Windows Vista Home Premium. The printing problem is that it prints
> out the html code instead of the stuff that I need. I did the installation
> manually, not with the cd, so I don't think there is any extra stuff that
> needs deleted. We had both Verizon and AOL installed until yesterday when
> I
> uninstalled the AOL stuff so I think the problem came from that not
> Verizon.
> "PA Bear" wrote:
Quote:
>> What printing problems? Windows version? Does uninstalling all software
>> you installed from the Verizon CD (none of which you need now) resolve
>> the
>> problem?
>> ~Robear Dyer (PA Bear)
>> MS MVP-Windows (IE, OE, Security, Shell/User)
>> AumHa VSOP & Admin http://aumha.net
>> DTS-L.ORG http://66.39.69.143/
>> tif wrote:
Quote:
>>> Hello, I have read a lot of other posts on this and tried going in to
>>> make
>>> ie my default browser but that still did not help. Any other
>>> suggestions?
>>> I
>>> never had this problem until I unistalled the aol software on my
>>> computer
>>> (we recently switched from aol dial up to verizon dsl and I figured I
>>> didn't need it anymore). Do you think that's what messed it up? I am
>>> ready
>>> to pull my hair out and would appreciate any help! Thanks!
Old 12-08-2007   #2 (permalink)
tif
No, I don't think I have installed any Yahoo anything, oh wait I do have a
Yahoo toolbar installed because of my email...No MacAfee, we have Norton. I
will have to check and see if it sticks when I reboot. I will post back in a
few after I check.
> Security Center?
> ~PA Bear
> > I
> > Verizon.
> >> the
> >> problem?
> >>> make
> >>> suggestions?
> >>> I
> >>> computer
> >>> ready
Old 12-08-2007   #3 (permalink)
tif
Ok I rebooted and checked and it still has IE listed as my default.
> few after I check.
> > Security Center?
> > ~PA Bear
> > > I
> > > Verizon.
> > >> the
> > >> problem?
> > >>> make
> > >>> suggestions?
> > >>> I
> > >>> computer
> > >>> ready
Old 12-09-2007   #4 (permalink)
PA Bear
Uninstall Yahoo Companion (toolbar) and anything else named "Yahoo" via
Add/Remove Programs, then reboot & test. If still no joy:
1. After making certain you have a copy of your Product Key, uninstall all
Norton software via Add/Remove Programs.
2. Enable the Windows Firewall.
3. Run this removal tool:
http://service1.symantec.com/SUPPORT...05033108162039
4. Reboot, and *immediately* install the 30-day free trial version of NOD32*
or KAV7**
5. Manually update your new anti-virus application then run a full system
scan.
Do your problems persist now?
[Don't forget to subscribe to your new AV app or uninstall it then reinstall
the Norton application before the free-trial period expires! Should you
decide to reinstall the Norton application, I recommend not installing any
Norton Add-ons for a while.]
* www.eset.com/download/index.php
** http://usa.kaspersky.com/trials/home.../anti-virus-7/
tif wrote:
> "tif" wrote:
>> a
>> I
>> in
>> a few after I check.
>>> Security Center?
>>>> prints
>>>> installation manually, not with the cd, so I don't think there is any
>>>> extra stuff that needs deleted. We had both Verizon and AOL installed
>>>> until yesterday when I
>>>> Verizon.
>>>>> software you installed from the Verizon CD (none of which you need
>>>>> now)
>>>>> resolve the
>>>>> problem?
>>>>>> make
>>>>>> suggestions?
>>>>>> I
>>>>>> computer
>>>>>> ready
Old 12-09-2007   #5 (permalink)
tif
Thanks! I will try it out and see what happens.
> or KAV7**
> scan.
> tif wrote:
> > "tif" wrote:
> >> a
> >> I
> >> in
> >>> Security Center?
> >>>> prints
> >>>> Verizon.
> >>>>> now)
> >>>>> resolve the
> >>>>> problem?
> >>>>>> make
> >>>>>> suggestions?
> >>>>>> I
> >>>>>> computer
> >>>>>> ready
Old 12-09-2007   #6 (permalink)
tif
I uninstalled the yahoo toolbar and rebooted and it still wouldn't work. I am
very nervous about taking out norton and then having to reinstall it. I am a
very inexperienced computer user and I am afraid I will mess it up. Is there
anything else I could try? I'm about to give up and use Firefox instead. I
don't understand why this happened. Everything worked fine up until I removed
all the AOL stuff on the computer...
> > or KAV7**
> > scan.
> > tif wrote:
> > >> a
> > >> I
> > >> in
> > >>> Security Center?
> > >>>> prints
> > >>>> Verizon.
> > >>>>> now)
> > >>>>> resolve the
> > >>>>> problem?
> > >>>>>> make
> > >>>>>> suggestions?
> > >>>>>> I
> > >>>>>> computer
> > >>>>>> ready
Old 12-09-2007   #7 (permalink)
PA Bear
=> Does this behavior persist if you start IE7 in No Add-ons mode? To start
IE7 in No Add-ons mode:
1. Right-click on the blue IE desktop icon and select Start without Add-ons;
2. Start > (All) Programs > Accessories > System Tools > Internet Explorer
(No add-ons).
Troubleshooting and Internet Explorer’s (No Add-ons) Mode:
http://blogs.msdn.com/ie/archive/2006/07/25/678113.aspx
=> Does the problem persist if you Reset IE7 Settings (RIES)?
http://support.microsoft.com/kb/923737 <= Read before using!
Other than above, I'm out of ideas. Maybe someone in the Vista
Print_Fax_Scan newsgroup will have some ideas for you, tif. From what I've
seen, no Norton application works well in Vista yet.
~PA Bear
tif wrote:
> am very nervous about taking out norton and then having to reinstall it. I
> am a very inexperienced computer user and I am afraid I will mess it up.
> Is
> there anything else I could try? I'm about to give up and use Firefox
> instead. I don't understand why this happened. Everything worked fine up
> until I removed all the AOL stuff on the computer...
>>> all
>>> NOD32* or KAV7**
>>> system
>>> scan.
>>> reinstall the Norton application before the free-trial period expires!
>>> Should you decide to reinstall the Norton application, I recommend not
>>> installing any Norton Add-ons for a while.]
>>>>> have
>>>>> a
>>>>> Norton. I
>>>>> back
>>>>> in
>>>>>> newsgroup.
>>>>>> McAfee
>>>>>> Security Center?
>>>>>> the
>>>>>>> prints
>>>>>>> any
>>>>>>> installed
>>>>>>> Verizon.
>>>>>>>> now)
>>>>>>>> resolve the
>>>>>>>> problem?
>>>>>>>>> to make
>>>>>>>>> suggestions?
>>>>>>>>> I
>>>>>>>>> computer
>>>>>>>>> figured
>>>>>>>>> I didn't need it anymore). Do you think that's what messed it up?
>>>>>>>>> I
>>>>>>>>> am ready
Old 12-10-2007   #8 (permalink)
tif
Thank you so much for your help PA Bear! I truly appreciate it! Last night my
brother in law was helping me and after several unsuccessful tries this is
what finally made it work: Tools-Internet Options-General-Accessibility- and
then we check marked the boxes that said--ignore font styles specified on
webpages, ignore font sizes specified on webpages. And voila, now it
works!!(well at least it worked last night, who knows about today!)
Oh, yeah, I have found that nothing works well with Vista, lol
> (No add-ons).
> ~PA Bear
> > Is
> >>> all
> >>> NOD32* or KAV7**
> >>> system
> >>> scan.
> >>>>> have
> >>>>> a
> >>>>> Norton. I
> >>>>> back
> >>>>> in
> >>>>>> newsgroup.
> >>>>>> McAfee
> >>>>>> Security Center?
> >>>>>> the
> >>>>>>> prints
> >>>>>>> any
> >>>>>>> installed
> >>>>>>> Verizon.
> >>>>>>>> now)
> >>>>>>>> resolve the
> >>>>>>>> problem?
> >>>>>>>>> to make
> >>>>>>>>> suggestions?
> >>>>>>>>> I
> >>>>>>>>> computer
> >>>>>>>>> figured
> >>>>>>>>> I
> >>>>>>>>> am ready
Old 12-10-2007   #9 (permalink)
PA Bear
YW & thanks for your feedback on this. That's an interesting workaround but
IMHO having those options unchecked was not the cause of the problem.
~PA Bear
tif wrote:
> my brother in law was helping me and after several unsuccessful tries this
> is what finally made it work: Tools-Internet
> and then we check marked the boxes that said--ignore font styles specified
> on webpages, ignore font sizes specified on webpages. And voila, now it
> "PA Bear" wrote:
>> start IE7 in No Add-ons mode:
>> Add-ons;
>> Explorer
>> (No add-ons).
>> I've
>> ~PA Bear
>> tif wrote:
>>> I
>>> I
>>> Is
>>>>> via
>>>>> all
>>>>> NOD32* or KAV7**
>>>>> system
>>>>> scan.
>>>>>>> have
>>>>>>> a
>>>>>>> Norton. I
>>>>>>> back
>>>>>>> in
>>>>>>>> newsgroup.
>>>>>>>> McAfee
>>>>>>>> Security Center?
>>>>>>>> the
>>>>>>>>> prints
>>>>>>>>> any
>>>>>>>>> installed
>>>>>>>>> not
>>>>>>>>> Verizon.
>>>>>>>>>> need
>>>>>>>>>> now)
>>>>>>>>>> resolve the
>>>>>>>>>> problem?
>>>>>>>>>>> in
>>>>>>>>>>> to make
>>>>>>>>>>> suggestions?
>>>>>>>>>>> I
>>>>>>>>>>> computer
>>>>>>>>>>> figured
>>>>>>>>>>> up?
>>>>>>>>>>> I
>>>>>>>>>>> am ready
Printing problems Vista print fax & scan
Re: ie 7 printing problems Vista print fax & scan
Printing Problems Vista General
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
