| | Manual duplex print does not work with Konica-Minolta PagePro 1350 Manual duplex with this printer works in Windows XP. After printing of the first half, dialog message is displayed and when it is confirmed (after manually rotating and re-inserting the sheets), the other pages are printed out. I've upgraded to Vista now, but if I print something using this duplex printing, everything is printed without the dialog message at once. Does anybody happen to know how to make it work? |
| Minolta PagePro 1250W on Vista 64-bit | Vista print fax & scan | |||
| Cannot print using Vista 64bit, Konica Minolta 2500W | Vista print fax & scan | |||
| Re: Minolta Pagepro 1100L on Vista | Vista print fax & scan | |||
| Trouble getting Konica Minolta PagePro 1350w to work with vista x6 | Vista print fax & scan | |||
| Konica Minolta 2400W | Vista General | |||
