| | faxing problems Okay, here goes: I installed the fax solutions driver from my Lexmark All in One. It supposedly installed correctly. The correct modem was found and i get a wonderful graphic for faxing. Each time I click on "send a new fax" I get an error message that says: Fax Ctr.exe has stopped working. I had no trouble with the printer part of my all in one, but see no reason why my fax machine portion will not work. I have contacted Lexmark ,who sent me to microsoft who sent me to my comp manufacturer. I am beyond frustrated because I really need my fax option for my business. If anyone has a solution please let me know. I am now yearning to havee XP instead of Vista! -- Al Cicere |
| | Re: faxing problems Third party software. Your resolution is with Lexmark or the OEM. For them to imply otherwise is irresponsible. -- Russ Valentine [MVP-Outlook] "Al Cicere" <AlCicere@xxxxxx> wrote in message news:1752FCE1-2E61-4ED9-8376-5320739AD322@xxxxxx Quote: > Okay, here goes: I installed the fax solutions driver from my Lexmark All > in > One. It supposedly installed correctly. The correct modem was found and i > get > a wonderful graphic for faxing. Each time I click on "send a new fax" I > get > an error message that says: Fax Ctr.exe has stopped working. I had no > trouble > with the printer part of my all in one, but see no reason why my fax > machine > portion will not work. I have contacted Lexmark ,who sent me to microsoft > who sent me to my comp manufacturer. I am beyond frustrated because I > really > need my fax option for my business. If anyone has a solution please let me > know. I am now yearning to havee XP instead of Vista! > -- > Al Cicere |
| Help! with Faxing | Vista print fax & scan | |||
| faxing | Vista print fax & scan | |||
| Re: Nobody is Faxing huh? | Vista print fax & scan | |||
