| | Phone Numbers Missing when using Fax and Scan When using Fax and Scan program in Vista Ultimate, the contact list (when selecting a new fax) does not show the fax numbers available, only email addresses. I recently added a new harddrive and reinstalled Ultimate, but no changes other than the hd swap were done, I remember prior to the change the fax numbers would show in my contact list, but now they do not. Any ideas? Thanks, Rudy |
| | Re: Phone Numbers Missing when using Fax and Scan You neglected to mention what you are using as your default Contacts Manager. You should also include how you migrated your data to the new hard drive. -- Russ Valentine [MVP-Outlook] "rudysm" <rudysm@xxxxxx> wrote in message news:323EE2A2-4EBB-4A2D-A4D5-21CB6153C922@xxxxxx Quote: > When using Fax and Scan program in Vista Ultimate, the contact list (when > selecting a new fax) does not show the fax numbers available, only email > addresses. I recently added a new harddrive and reinstalled Ultimate, but > no > changes other than the hd swap were done, I remember prior to the change > the > fax numbers would show in my contact list, but now they do not. Any > ideas? > > Thanks, Rudy |
| | Re: Phone Numbers Missing when using Fax and Scan I am using Outlook 2007 and I started from scratch on the hard drive, clean install. Thanks. "Russ Valentine [MVP-Outlook]" wrote: Quote: > You neglected to mention what you are using as your default Contacts > Manager. You should also include how you migrated your data to the new hard > drive. > -- > Russ Valentine > [MVP-Outlook] > "rudysm" <rudysm@xxxxxx> wrote in message > news:323EE2A2-4EBB-4A2D-A4D5-21CB6153C922@xxxxxx Quote: > > When using Fax and Scan program in Vista Ultimate, the contact list (when > > selecting a new fax) does not show the fax numbers available, only email > > addresses. I recently added a new harddrive and reinstalled Ultimate, but > > no > > changes other than the hd swap were done, I remember prior to the change > > the > > fax numbers would show in my contact list, but now they do not. Any > > ideas? > > > > Thanks, Rudy |
| Disappearing phone numbers | Vista General | |||
| Fax and scan, ccell phone | Vista print fax & scan | |||
| phone numbers | Vista security | |||
| Microsoft Live Onecare phone numbers | Vista General | |||
| disappearing phone numbers | Vista General | |||
