| | print driver successfully installed but still a problem with print I own a Dell XPS 410 running 32 bit Vista Ultimate. I have a HP Laserjet 4L parallel printer that I am trying to connect to the XPS 410. Because the printer has a parallel cable, it was necessary for me to buy a USB/Parallel adapter to contact the PC to the printer. I attempted to use the "add a printer" facility and my system successfully found a driver for the printer. However, there is some kind of a problem and the printer won't print. I opened device Manager and there is a yellow exclamation point next to the icon for "USB Printing Support". When I clicked it, it said "This device cannot start (Code 10). Click "Check for Solutions" to send data about this device to Microsoft and to see if there is a solution available". Below that was a button labeled "check for solutions". When I clicked that button, a new dialog box popped out and asked "Do you want to send more info about the problem? Additional details about what went wrong can help Microsoft create a solution" I clicked "send information". There was also another button on the same dialog box that had additional details. When I clicked that button, the following was written: "Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10". Does anyone have a clue as to what might be the problem? Thanks chief Jay |
| | Re: print driver successfully installed but still a problem with print What hardware is the USB to parallel cable? I know the 4L will work with a Belkin F5U002 cable because I have this configuration. I only will use this cable since it has a proven track record for me when other cables have failed. The hardware in your cable may need some device drivers so check the vendor site for Vista drivers. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "chiefjay" <chiefjay@xxxxxx> wrote in message news:8B5F4795-BB79-495D-88A4-B2E31BC7A1E0@xxxxxx Quote: >I own a Dell XPS 410 running 32 bit Vista Ultimate. I have a HP Laserjet 4L > parallel printer that I am trying to connect to the XPS 410. Because the > printer has a parallel cable, it was necessary for me to buy a > USB/Parallel > adapter to contact the PC to the printer. I attempted to use the "add a > printer" facility and my system successfully found a driver for the > printer. > However, there is some kind of a problem and the printer won't print. I > opened device Manager and there is a yellow exclamation point next to the > icon for "USB Printing Support". When I clicked it, it said "This device > cannot start (Code 10). Click "Check for Solutions" to send data about > this > device to Microsoft and to see if there is a solution available". Below > that > was a button labeled "check for solutions". When I clicked that button, a > new > dialog box popped out and asked "Do you want to send more info about the > problem? Additional details about what went wrong can help Microsoft > create a > solution" I clicked "send information". There was also another button on > the > same dialog box that had additional details. When I clicked that button, > the > following was written: "Windows was able to successfully install device > driver software, but the driver software encountered a problem when it > tried > to run. The problem code is 10". > Does anyone have a clue as to what might be the problem? > Thanks > chief Jay |
| | Re: print driver successfully installed but still a problem with p I bought the cable on EBay from a Hong Kong based company called Pointing Mouse. I guess I thought that all cables are created equally. There is a diskette that came with the cable, but there is a notation that no drivers are needed with windows Vista, so I didn't fully examine the files on the diskette. I guess it will be ncessary to go out and find the Belkin cable that you suggested. By the way, do you have any idea what "problem code 10" is? chief jay "Alan Morris [MSFT]" wrote: Quote: > What hardware is the USB to parallel cable? I know the 4L will work with a > Belkin F5U002 cable because I have this configuration. I only will use this > cable since it has a proven track record for me when other cables have > failed. > > The hardware in your cable may need some device drivers so check the vendor > site for Vista drivers. > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/search/?adv=1 > > This posting is provided "AS IS" with no warranties, and confers no rights. > > "chiefjay" <chiefjay@xxxxxx> wrote in message > news:8B5F4795-BB79-495D-88A4-B2E31BC7A1E0@xxxxxx Quote: > >I own a Dell XPS 410 running 32 bit Vista Ultimate. I have a HP Laserjet 4L > > parallel printer that I am trying to connect to the XPS 410. Because the > > printer has a parallel cable, it was necessary for me to buy a > > USB/Parallel > > adapter to contact the PC to the printer. I attempted to use the "add a > > printer" facility and my system successfully found a driver for the > > printer. > > However, there is some kind of a problem and the printer won't print. I > > opened device Manager and there is a yellow exclamation point next to the > > icon for "USB Printing Support". When I clicked it, it said "This device > > cannot start (Code 10). Click "Check for Solutions" to send data about > > this > > device to Microsoft and to see if there is a solution available". Below > > that > > was a button labeled "check for solutions". When I clicked that button, a > > new > > dialog box popped out and asked "Do you want to send more info about the > > problem? Additional details about what went wrong can help Microsoft > > create a > > solution" I clicked "send information". There was also another button on > > the > > same dialog box that had additional details. When I clicked that button, > > the > > following was written: "Windows was able to successfully install device > > driver software, but the driver software encountered a problem when it > > tried > > to run. The problem code is 10". > > Does anyone have a clue as to what might be the problem? > > Thanks > > chief Jay > > |
| | Re: print driver successfully installed but still a problem with p the spooler does not report this it's from device manager. The USB Controller Is Not Recognized and a Code 10 Error Message Appears in Device Manager (297511) - On a computer whose motherboard has a Silicon Integrated Systems (SIS) chipset, Device Manager may display the following error message for the USB controller: Code 10 - the device cannot start. ... However, the controller reverts to the "code 10" status when you restart the computer. http://support.microsoft.com/kb/297511/en-us -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "chiefjay" <chiefjay@xxxxxx> wrote in message news:7054F430-0EC2-4093-8E2F-B17C30A1941E@xxxxxx Quote: >I bought the cable on EBay from a Hong Kong based company called Pointing > Mouse. I guess I thought that all cables are created equally. There is a > diskette that came with the cable, but there is a notation that no drivers > are needed with windows Vista, so I didn't fully examine the files on the > diskette. I guess it will be ncessary to go out and find the Belkin cable > that you suggested. By the way, do you have any idea what "problem code > 10" > is? > chief jay > > "Alan Morris [MSFT]" wrote: > Quote: >> What hardware is the USB to parallel cable? I know the 4L will work with >> a >> Belkin F5U002 cable because I have this configuration. I only will use >> this >> cable since it has a proven track record for me when other cables have >> failed. >> >> The hardware in your cable may need some device drivers so check the >> vendor >> site for Vista drivers. >> >> -- >> Alan Morris >> Windows Printing Team >> Search the Microsoft Knowledge Base here: >> http://support.microsoft.com/search/?adv=1 >> >> This posting is provided "AS IS" with no warranties, and confers no >> rights. >> >> "chiefjay" <chiefjay@xxxxxx> wrote in message >> news:8B5F4795-BB79-495D-88A4-B2E31BC7A1E0@xxxxxx Quote: >> >I own a Dell XPS 410 running 32 bit Vista Ultimate. I have a HP Laserjet >> >4L >> > parallel printer that I am trying to connect to the XPS 410. Because >> > the >> > printer has a parallel cable, it was necessary for me to buy a >> > USB/Parallel >> > adapter to contact the PC to the printer. I attempted to use the "add a >> > printer" facility and my system successfully found a driver for the >> > printer. >> > However, there is some kind of a problem and the printer won't print. >> > I >> > opened device Manager and there is a yellow exclamation point next to >> > the >> > icon for "USB Printing Support". When I clicked it, it said "This >> > device >> > cannot start (Code 10). Click "Check for Solutions" to send data about >> > this >> > device to Microsoft and to see if there is a solution available". Below >> > that >> > was a button labeled "check for solutions". When I clicked that button, >> > a >> > new >> > dialog box popped out and asked "Do you want to send more info about >> > the >> > problem? Additional details about what went wrong can help Microsoft >> > create a >> > solution" I clicked "send information". There was also another button >> > on >> > the >> > same dialog box that had additional details. When I clicked that >> > button, >> > the >> > following was written: "Windows was able to successfully install device >> > driver software, but the driver software encountered a problem when it >> > tried >> > to run. The problem code is 10". >> > Does anyone have a clue as to what might be the problem? >> > Thanks >> > chief Jay >> >> |
| HP Deskjet 3820 Installed but does not print | Vista print fax & scan | |||
| Device driver software was not successfully installed | Vista hardware & devices | |||
| Windows 2008 print server at terminal services - printer driver problem | Vista print fax & scan | |||
| Cant print from Vista through XP!!? driver not installed?! | Drivers | |||
| Cannot print to network printer on the PC it is installed on | Vista print fax & scan | |||
