Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - "Print spooler stopped" Vista Ultimate/HP LaserJet 2840 help?
Old 01-13-2008   #1 (permalink)
JStar
I am using Windows Vista Ultimate in my new business. I have new Vista
certified computers that I built. everything is working well, except the
print spooler. I cannot get the print spooler to stay started no matter how I
set it under "services." I'm using an HP LaserJet 2840 All-in-one printer
with all the Windows Vista drivers and firmware installed. HP says that the
printer is compatible. I checked all cabling, connections, and hardware.
Using on several identical computers all using same "OS." and Networking is
fine, programs are fine, internet is fine.
Is there anyone out there who has come across this problem, and if so, is
there a work-around or fix?
Windows Vista Print Spooler (under Services tab) "Failed to read D Vista print fax & scan
upgrading from "Vista Home Premium" to "Vista Business" or "Vista Ultimate" Vista account administration
ERROR!!! "Spooler Subsystem App Stopped Working And Was Closed" Vista print fax & scan
Have Vista Home Premium - is "Business" or "Ultimate" better? Vista General
Print Spooler - Vista Ultimate + HP Color LaserJet 5550dtn Vista print fax & scan
