Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista Tutorial - Word 2003 wont print wireless
Old 01-21-2008   #1 (permalink)
Ageingrodder
Guest
I recently purchased two Dell laptops which made me switch to Vista Home
version. At the same time I also installed a wireless system. Nothing like
asking for problems. Other than a few "bumps" in the road, everything seems
to be working okay except I can't print Word from my laptop to my printer
wirelessly. Explorer and other programs such as Excell and Outlook seem to
work fine. I checked for driver and Word updates and even reloaded Word then
loaded it on to my wife's laptop but she has the same problem. I've also
reinstalled the printer. I see comments from other people on the web with
similar problems, but never an answer.
Anybody have any suggestions? :<
Old 01-23-2008   #2 (permalink)
Cari \(MS-MVP\)
Guest
Re: Word 2003 wont print wireless
Are you sure in Word that you are printing to the correct printer? Use
File, Print, rather than the print icon on the toolbar, it may be that
you're sending it to a virtual printer instead.
Cari (MS-MVP Printing & Imaging)
http://www.coribright.com/windows
"Ageingrodder" <Ageingrodder@xxxxxx> wrote in message
news:BA85257B-EED2-4B1C-98A6-BD9A7E2821D9@xxxxxx
> like
> seems
> to
> then
Old 01-24-2008   #3 (permalink)
Ageingrodder
Guest
Thank you for your suggestion even though that wasn't the problem. I finally
solved the problem, but I'm not positve how because I did two things before I
tested the connection. One, I loaded printer updates in my server computer,
and two I reset the print configuration from direct to server. Someday I'll
change it back and see if that was the fix. Thanks again for responding.
> > like
> > seems
> > to
> > then
Saving Documents Created in Word 2007 to be Compatible with Word 2003 Microsoft Office
print envelopes word 2003 vista home premium Vista print fax & scan
No longer able to print from MS Word 97 & 2003 Docs Vista General
Send Word document by email from Word 2003 not working with WLM Live Mail
Creating Word document of Word 97-2003 file type on the New menu in Vista Vista General
