| | Can anyone help please? Printer wont print Im having trouble with my printer. it was working fine and it suddenly stopped. I have windows xp and a hp psc 1317 series. I decided to downloaded the software and the drivers so that it is compatible with xp. The photocopier and scanner work but the printer doesn't. I have tried unistalling and reainstalling, i have changed the ink cartridge and i cant think what else i can do. I need this working as soon as possible im doing a postgrad at uni, and im ususally superglued to my computer Thanks in advance for any comments |
| | Re: Can anyone help please? Printer wont print In article <D6E5F57D-C753-435F-876C-71B4A1D09B8F@xxxxxx>, Fmck1983 wrote: Quote: > *it was working fine and it suddenly* > stopped. *I have windows xp and a hp psc 1317 series. *I decided to* > downloaded the software and the drivers so that it is compatible with xp. * > The photocopier and scanner work but the printer doesn't. This is a VISTA Newsgroup -- you are using XP still? You must install the software before you connect the printer's USB cable to the PC -- if you did not uninstall everything and start again but do not connect the USB cable to the PC until the installation tells you to or until you reach Finish. |
| | Re: Can anyone help please? Printer wont print "fmck1983" <fmck1983@xxxxxx> wrote in message news 6E5F57D-C753-435F-876C-71B4A1D09B8F@xxxxxxQuote: > Im having trouble with my printer. it was working fine and it suddenly > stopped. I have windows xp and a hp psc 1317 series. I decided to > downloaded the software and the drivers so that it is compatible with xp. > The photocopier and scanner work but the printer doesn't. > > I have tried unistalling and reainstalling, i have changed the ink > cartridge > and i cant think what else i can do. > > I need this working as soon as possible im doing a postgrad at uni, and im > ususally superglued to my computer > > Thanks in advance for any comments System Restore back to a point before the printer started to act up? Printers can be fussy about installations. Remove the software you downloaded and installed and start from square one. Follow the HP installation instructions to the letter! Post back with more information. Again, it is not clear if your OS is XP or Vista. |
| Vista Can't Print to Win2K shared printer-Test Print disappears fr | Vista networking & sharing | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista installation & setup | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista print fax & scan | |||
| Deleted Printer but icon still there & printer wont auto install & wont print | Vista performance & maintenance | |||
| Printer Wont Print From Laptop | Vista print fax & scan | |||
