Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - remote connection
Old 01-26-2008   #1 (permalink)
Geoff Kidd
remote connection
Hi
Using vista to connect remotely to sbs 2003 but printers do not connect,
drivers are loaded on sbs. Using xp client to connect no problem.
Do you have to allow remote printing in vista somewhere or create a share ?
Geoff Kidd
invalid connection file on remote desktop connection Vista General
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
VB.NET application cliick-once deployment via internet - Error - Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. .NET General
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
remote desktop connection? AKA remote access? Vista General
