| | my Lexmark X73 printer is not set up for vista help I tryed to hook up my all in one printer to my pc , installed driver but it is not set up for vista . what can I do? |
| | Re: my Lexmark X73 printer is not set up for vista help "laurie" <laurie@xxxxxx> wrote in message news:32B405C0-1ED7-47DA-83FE-F06DFB8EFACF@xxxxxx Quote: >I tryed to hook up my all in one printer to my pc , installed driver but >it > is not set up for vista . what can I do? http://downloads.lexmark.com/cgi-per...od=Lexmark+X73 there is no Vista driver for your X73. That's not good for you. If the XP driver that the printer shipped with does not work, you are probably out of luck. Does the unit just not work at all, or do you have some capability with it? Like, does it print but not copy or scan? Or scan and print, but not copy and so on? |
| Lexmark Printer and Vista | Vista print fax & scan | |||
| Lexmark printer in Vista | Drivers | |||
| Lexmark X73 Printer Won't Work with Vista! | Vista hardware & devices | |||
| Vista and Lexmark X2470 printer.< All In One > | Vista print fax & scan | |||
| New Lexmark printer with vista drivers | Vista General | |||
