Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Help installing printer (lexmark 2300) on vista
Old 02-18-2008   #1 (permalink)
Michelle
the printer completes the install and it is set for the default printer...but
nothing happens when I try to print....
Old 02-19-2008   #2 (permalink)
Kevin
Re: Help installing printer (lexmark 2300) on vista
"Michelle" <Michelle@xxxxxx> wrote in message
news:A7FDC757-CA00-4D50-9CEE-5EC617992D25@xxxxxx
> printer...but
Are you installing the driver found on this page?
http://www.downloaddelivery.com/en/cpddrivers/487.html
Does the printer generate a test page? How are you trying to initiate the
print job?
Old 06-16-2009   #3 (permalink)
Sonja V M
Driver site does not work.
Sonja V M
Sonja V M's Profile: http://forums.techarena.in/members/106318.htm
View this thread: http://forums.techarena.in/vista-print-fax/916693.htm
Minolta Magicolor 2300 DL Printer Driver Drivers
Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Vista print fax & scan
Lexmark Drivers for Lexmark 2300 series printers Vista General
installing a lexmark x5150 printer Vista print fax & scan
HP LaserJet 2300 Printer Vista General
