| | Same Problem I'm having the same problem but with an HP Laserjet 1022. I have reinstalled the LJ 1022 several times, but when you print from Adobe it kicks the spooler out. What you can do is unplug the printer from the computer, reboot and the spooler will come back. Then you reinstall the printer drivers/ software, plug it in when asked for and as long as the user doesn't print an Adobe PDF, the printer won't kick out. I believe this to be an HP issue with their driver that is almost 1yr old... any help is very much appreciated. |
| | Re: Same Problem I'd contact Adobe and ask them. If it prints fine with all other applications, then it's definitely something wrong with Adobe Acrobat. -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows <afedrid@xxxxxx> wrote in message news:3237696d-d2b7-4808-b4bc-98b1516d46f4@xxxxxx Quote: > I'm having the same problem but with an HP Laserjet 1022. I have > reinstalled the LJ 1022 several times, but when you print from Adobe > it kicks the spooler out. > > What you can do is unplug the printer from the computer, reboot and > the spooler will come back. Then you reinstall the printer drivers/ > software, plug it in when asked for and as long as the user doesn't > print an Adobe PDF, the printer won't kick out. > > I believe this to be an HP issue with their driver that is almost 1yr > old... any help is very much appreciated. |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
