Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Not A Normal Printer Problem
Old 03-01-2008   #1 (permalink)
Vista Ultimate 32bit
I do not have a printer hooked up or ever loaded onto my laptop and do not plan on doing so. I read that to print to file that the Microsoft XPS Document Writer should remain as the "Printer" even though one is not installed.
In the Event Viewer I constantly get "SpoolerWin32SPL" Warnings with an event ID of 4. I checked the cures at Microsoft and they all pertain to having a real printer. I suspect that I could shut down all spooler and print activities but I'm not sure that I might not be affecting something else by doing so.
Any suggestions by anyone who may have had this problem or seen this same issue in writing?
Thanx,
Frag
Old 03-03-2008   #2 (permalink)
Cari \(MS-MVP\)
Re: Not A Normal Printer Problem
If you're not using the XPS Writer (installed with Office) then disable it.
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
"defrag1720" <defrag1720.35mox0@xxxxxx-mx.forums.net> wrote in message
news:defrag1720.35mox0@xxxxxx-mx.forums.net...
> not installed.
> Thanx,
> Frag
> defrag1720
Old 03-03-2008   #3 (permalink)
Thanks for the reply. I'll give it a shot. Just thought I read to keep the XPS active for documents, but I really don't use it.
Frag
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
Solved Is this normal? General Discussion
printer problem to domain's printer Vista General
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
Is this normal? Vista installation & setup
