| vista 64 ultimate | IE printing problems SP1 Hi all running vista 64 SP1 RTM cannot print from IE nor print preview unless I turn UAC off in control panel. Cannot print even if opening IE as admin. (some sort of error message about C:/users/username/appdata/local/temp/low/ and some files therein.) Note, on a different machine with vista 32 SP1 beta2 refresh (never got around to installing SP1 RTM on this box) - UAC enabled and no print problem at all any thoughts? |
| | Re: IE printing problems SP1 Was it printing fine before SP1? What make and model of printer are you using? Does it print correctly from all other applications? -- Cari (MS-MVP) Printing & Imaging www.coribright.com/windows "entdoc" <entdoc.35r7f3@xxxxxx-mx.forums.net> wrote in message news:entdoc.35r7f3@xxxxxx-mx.forums.net... Quote: > > Hi all > running vista 64 SP1 RTM > cannot print from IE nor print preview unless I turn UAC off in control > panel. Cannot print even if opening IE as admin. > (some sort of error message about > C:/users/username/appdata/local/temp/low/ and some files therein.) > Note, on a different machine with vista 32 SP1 beta2 refresh (never got > around to installing SP1 RTM on this box) - UAC enabled and no print > problem at all > any thoughts? > > > -- > entdoc |
| vista 64 ultimate | Re: IE printing problems SP1 this was a clean install of vista 64 SP1 RTM the printer is an HPofficejet 6100 series. on this machine all other apps DO print even if UAC is on. on my older machine, with vista 32 SP1 beta2 IE prints fine even with UAC on. |
| | Re: IE printing problems SP1 32 or 64 bit IE. The only way I know how to tell is using task manager. If it has the *32 it's the 32 bit version. Attempt using the other version and see if you get the same result. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "entdoc" <entdoc.35wkh5@xxxxxx-mx.forums.net> wrote in message news:entdoc.35wkh5@xxxxxx-mx.forums.net... Quote: > > this was a clean install of vista 64 SP1 RTM > the printer is an HPofficejet 6100 series. > on this machine all other apps DO print even if UAC is on. > > on my older machine, with vista 32 SP1 beta2 IE prints fine even with > UAC on. > > > -- > entdoc |
| vista 64 ultimate | Re: IE printing problems SP1 same issue with IE 32 and IE 64 in both cases all apps except IE print with UAC on in both cases with UAC off IE printing is fine |
| | #6 (permalink) |
| | RE: IE printing problems SP1 i got same problem vista home premium sp1. only works with UAC off, was ok yesterday?? arthos "entdoc" wrote: Quote: > > Hi all > running vista 64 SP1 RTM > cannot print from IE nor print preview unless I turn UAC off in control > panel. Cannot print even if opening IE as admin. > (some sort of error message about > C:/users/username/appdata/local/temp/low/ and some files therein.) > Note, on a different machine with vista 32 SP1 beta2 refresh (never got > around to installing SP1 RTM on this box) - UAC enabled and no print > problem at all > any thoughts? > > > -- > entdoc > |
| Printing problems | Vista print fax & scan | |||
| Re: still problems with printing in ie7 | Vista print fax & scan | |||
| Printing Problems | Vista General | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
| printing problems | Vista print fax & scan | |||
