Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Print Spooler Not Running
Old 03-06-2008   #1 (permalink)
ToddW
In my 64-bit installation, the print spooler server suddenly stopped running
(and will not restart). I've tried cleaning out registry keys
(HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print), deleting the
files out of Windows (C:\Windows\System32\spool) to no avail.
The system log contains many of these:
Error Service Control Manager Eventlog Provider 7034 None
The application log contains these:
Warning SpoolerSpoolss 1035 None
The print spooler failed to load print provider localspl.dll. This can occur
because of system instability or a lack of system resources.
Error SpoolerSpoolss 1027 None
The system failed to initialize the local print provider: Error 0. This can
occur because of system instability or a lack of system resources.
Can someone help diagnose this issue??
Old 03-06-2008   #2 (permalink)
Cari \(MS-MVP\)
Re: Print Spooler Not Running
What is the exact text of the error message when you try to restart the
spooler?
http://www.coribright.com/windows/Article_Nine.htm
Cari (MS-MVP) Printing & Imaging
"ToddW" <ToddW@xxxxxx> wrote in message
news:17A6C357-D32D-46E1-9D3A-D433067BD92F@xxxxxx
> running
> occur
> can
Old 03-06-2008   #3 (permalink)
ToddW
I can start the service, but as soon as the printer control panel is opened,
the service stops.
System log:
Log Name: System
Source: Service Control Manager
Date: 3/6/2008 6:49:19 PM
Event ID: 7034
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: t
Description:
The Print Spooler Service service terminated unexpectedly. It has done this
4 time(s).
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager"
Guid="{555908D1-A6D7-4695-8E1E-26931D2012F4}" EventSourceName="Service
Control Manager" />
<EventID Qualifiers="49152">7034</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-03-07T02:49:19.000Z" />
<EventRecordID>57769</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>t</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">Print Spooler Service</Data>
<Data Name="param2">4</Data>
</EventData>
</Event>
Application Log (2 events):
Log Name: Application
Source: Microsoft-Windows-SpoolerSpoolss
Event ID: 1027
Task Category: None
Level: Error
Keywords: Classic
User: SYSTEM
Computer: t
Description:
Event Xml:
<System>
<Provider Name="Microsoft-Windows-SpoolerSpoolss" />
<EventID Qualifiers="49152">1027</EventID>
<Level>2</Level>
<Task>0</Task>
<EventRecordID>6265</EventRecordID>
<Channel>Application</Channel>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data>0</Data>
</EventData>
</Event>
Event ID: 1035
Task Category: None
Level: Warning
Keywords: Classic
User: SYSTEM
Computer: t
Description:
Event Xml:
<System>
<EventID Qualifiers="32768">1035</EventID>
<Level>3</Level>
<Task>0</Task>
<EventRecordID>6264</EventRecordID>
</System>
<EventData>
<Data>localspl.dll</Data>
</EventData>
</Event>
"Cari (MS-MVP)" wrote:
> spooler?
> > running
> > occur
> > can
Old 03-07-2008   #4 (permalink)
Alan Morris [MSFT]
does localspl.dll reside in \system32?
filver information
--a-- WAMD64 DLL ENU 6.0.6001.18000 shp 788,480 01-20-2008 localspl.dll
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/search/?adv=1
news:18984FEB-69C3-42B8-8D38-BD0AAB98E714@xxxxxx
>opened,
> the service stops.
> System log:
> Log Name: System
> Event ID: 7034
> Task Category: None
> Level: Error
> Keywords: Classic
> User: N/A
> Computer: t
> Description:
> this
> 4 time(s).
> Event Xml:
> <System>
> Control Manager" />
> <Level>2</Level>
> <Task>0</Task>
> <Opcode>0</Opcode>
> <Correlation />
> <Security />
> </System>
> <EventData>
> </EventData>
> </Event>
> Event ID: 1027
> Task Category: None
> Level: Error
> Keywords: Classic
> User: SYSTEM
> Computer: t
> Description:
> can
> Event Xml:
> <System>
> <Level>2</Level>
> <Task>0</Task>
> </System>
> <EventData>
> <Data>0</Data>
> </EventData>
> </Event>
> Event ID: 1035
> Task Category: None
> Level: Warning
> Keywords: Classic
> User: SYSTEM
> Computer: t
> Description:
> occur
> Event Xml:
> <System>
> <Level>3</Level>
> <Task>0</Task>
> </System>
> <EventData>
> </EventData>
> </Event>
>> spooler?
>> > running
>> > the
>> > occur
>> > can
Old 04-04-2008   #5 (permalink)
Scottwei
I had the same issue. The way that I was finally able to resolve it was by
going into Windows/system32/Spool/Printers and deleting all SHD and SPL
files. I deleted everything in there and then restarted the spooler. Now it
seems to be working fine. Hope it does for you too.
"ToddW" wrote:
> the service stops.
> System log:
> Log Name: System
> Event ID: 7034
> Task Category: None
> Level: Error
> Keywords: Classic
> User: N/A
> Computer: t
> Description:
> 4 time(s).
> Event Xml:
> <System>
> Control Manager" />
> <Level>2</Level>
> <Task>0</Task>
> <Opcode>0</Opcode>
> <Correlation />
> <Security />
> </System>
> <EventData>
> </EventData>
> </Event>
> Event ID: 1027
> Task Category: None
> Level: Error
> Keywords: Classic
> User: SYSTEM
> Computer: t
> Description:
> Event Xml:
> <System>
> <Level>2</Level>
> <Task>0</Task>
> </System>
> <EventData>
> <Data>0</Data>
> </EventData>
> </Event>
> Event ID: 1035
> Task Category: None
> Level: Warning
> Keywords: Classic
> User: SYSTEM
> Computer: t
> Description:
> Event Xml:
> <System>
> <Level>3</Level>
> <Task>0</Task>
> </System>
> <EventData>
> </EventData>
> </Event>
> > spooler?
> > > running
> > > occur
> > > can
print spooler service not running Vista print fax & scan
Print Spooler service is not running Vista print fax & scan
Print spooler stops running Vista print fax & scan
Vista print spooler service not running. Vista General
Print spooler service not running Vista print fax & scan
