| | I still am having problem Setting Up Network Printer via XP I just noticed that everything under the HP printer's properties is grayed out and so I cannot change anything. I thought ownership/privileges could be the cause of my not being able to print from this test VISTA machine over my LAN to the HP AIO printer which is connected directly via USB on my XP machine. But I can't change anything - I notice other things (e.g. share name) are grayed out also preventing change. At the very least I want to be able to regain control of all this. Remember - I can print in reverse over my LAN (using another printer). That is, from my XP machine to the EPSON printer connected to this test VISTA machine. I seem to be able to access and change files/folders at will from each machine to the other - so I feel I must have my LAN set up at least nearly correctly. Yes, I have turned User Account Control off. I am frustrated. Can anyone suggest where else I can look to solve this problem? Before I can this VISTA experiment of course. Thanks -GECKO |
| | Re: I still am having problem Setting Up Network Printer via XP Have you try to make an local print port on the Vista computer and used the Vista printer driver for it? Add a printer Add a local printer Create a new port Local Port \\remotemachine\printershare Select print driver Printer name "gecko" <alpha@xxxxxx> wrote in message news:uguit3hi4pctdp9t5rral4ujp84arld3qh@xxxxxx Quote: >I just noticed that everything under the HP printer's properties is > grayed out and so I cannot change anything. I thought > ownership/privileges could be the cause of my not being able to print > from this test VISTA machine over my LAN to the HP AIO printer which > is connected directly via USB on my XP machine. But I can't change > anything - I notice other things (e.g. share name) are grayed out also > preventing change. At the very least I want to be able to regain > control of all this. > > Remember - I can print in reverse over my LAN (using another printer). > That is, from my XP machine to the EPSON printer connected to this > test VISTA machine. I seem to be able to access and change > files/folders at will from each machine to the other - so I feel I > must have my LAN set up at least nearly correctly. > > Yes, I have turned User Account Control off. > > I am frustrated. Can anyone suggest where else I can look to solve > this problem? Before I can this VISTA experiment of course. > > Thanks > > -GECKO > |
| | Re: I still am having problem Setting Up Network Printer via XP On Thu, 13 Mar 2008 15:14:13 -0400, "Robert Schweitzer" <bschw@xxxxxx> wrote: Quote: >Have you try to make an local print port on the Vista computer and used the >Vista printer driver for it? > >Add a printer >Add a local printer >Create a new port >Local Port >\\remotemachine\printershare >Select print driver >Printer name I'll be danged! It worked first time! Thanks a meg. I guess this is why they pay you the big bucks? -GECKO |
| | RE: I still am having problem Setting Up Network Printer via XP http://technet.microsoft.com/en-us/l.../bb727037.aspx Have a read of the above link re Vista File and Printer Sharing. Permissions/Share info is there as well. If using Norton, McAfee, Trend Micro I.S., make sure file and printer sharing is enabled in THEIR firewall. 1st thing to do is make sure that the Workgroup Name of ALL the computers is the SAME. In Vista Network and Sharing: Network Discovery: ON (So it can see the other computers) Network set to Private (Public is for hotspots, airports, etc) File Sharing: ON Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared Docs) Password Protected: OFF (unless you want to set up identical usernames and passwords on ALL computers in your Network) If you have it ON, you will be asked for a username and password when you try to access a Vista computer from an XP computer. Also, run the XP’s Home Network File and Printer Sharing Wizard to include Vista in your “New” Network, even if you had an XP Network set up prior to adding a Vista computer to it. -- Mick Murphy - Qld - Australia "gecko" wrote: Quote: > I just noticed that everything under the HP printer's properties is > grayed out and so I cannot change anything. I thought > ownership/privileges could be the cause of my not being able to print > from this test VISTA machine over my LAN to the HP AIO printer which > is connected directly via USB on my XP machine. But I can't change > anything - I notice other things (e.g. share name) are grayed out also > preventing change. At the very least I want to be able to regain > control of all this. > > Remember - I can print in reverse over my LAN (using another printer). > That is, from my XP machine to the EPSON printer connected to this > test VISTA machine. I seem to be able to access and change > files/folders at will from each machine to the other - so I feel I > must have my LAN set up at least nearly correctly. > > Yes, I have turned User Account Control off. > > I am frustrated. Can anyone suggest where else I can look to solve > this problem? Before I can this VISTA experiment of course. > > Thanks > > -GECKO > > |
| Problem Setting Up Network Printer via XP | Vista print fax & scan | |||
| I still am having problem Setting Up Network Printer via XP | Vista General | |||
| I still am having problem Setting Up Network Printer via XP | Vista hardware & devices | |||
| Problem Setting Up Network Printer via XP | Vista General | |||
| Problem Setting Up Network Printer via XP | Vista hardware & devices | |||
