| | Fix IE7's printing problems I can no longer print from IE7 after installing the latest Microsft updates -- printing from other applications is unaffected. After some research I discovered there are 1000's of users with the same problem. I can print from IE 7 if I turn Protected Mode off, as suggested by a community member. Why can't Microsoft deliver less buggy software? This poor testing and buggy software cost me an hour of my time. I'm beginning to think I should move off the Microsoft Vista platform and go back to IE 6. -- Bill ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...print_fax_scan |
| | RE: Fix IE7's printing problems "ValcomTech" wrote: You are among the many. Do you have AVG 8 on your computer? If so find this post: Subject: Problem with AVG Free 8, Vista Home Premium SP1 and IE7 5/8/2008 on page 5 http://www.microsoft.com/communities....general&fltr= See Subject: RE: IE7 and No Web Page Printing 5/12/2008 12:38 PM PST on page 2 and Search Results: print_fax_scan Subject: Re: Printing - Vista Business SP1 / IE7 5/11/2008 9:54 AM PST http://www.microsoft.com/communities...c-9b18a16c916a If you do a search in this discussion group for "print_fax_scan" you will see many with the same problem. I have posted some hints on these pages. The one that works the best for me is : By right clicking on your IE7 startup icon and selecting {Properties, Shortcut} and then the advanced tab then check on the Run as Administrator box you will be able to print from IE. If you are running as a user this box will not allow you to check it. If that is the case use windows explorer to go to c:\Program Files\Internet Explorer\iexplore.exe. Right click on the iexplore file and select Send to desktop as shortcut. You will then be able to check the box on this icon to allow you to run as administrator. You will need to put your admin password in each time you open IE7 but at least you can print until the guilty party comes up with a solution. |
| where is IE7's Address box history | Vista file management | |||
| printing problems | Vista print fax & scan | |||
| IE printing problems SP1 | Vista print fax & scan | |||
| Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems | Vista installation & setup | |||
| Printing problems | Vista mail | |||
