| | Scanner problems My HP Scanjet 5530 worked perfectly on the first three pages of a four page document, i.e. it produced the pages in Word in all colors and with exact detail, so that I could Save As in the appropriate Folder, which contains many files of similar documents. On page four the Scanner ceased to produce the documents in color and some of the data was garbled. I then used the Picture instead of the Documents button when the document was properly reproduced, but when I want to Save As it produces the proper folder but it shows it as empty! HP suggested I try the latest driver, but this did not change the performance one iota. Which hardware is at fault - my computer or the Scanner? If the latter any suggestions how I can overcome the problem that when I click on Save As I get an empty folder instead of the one I have! |
| Problems with x64 fingerprint scanner! | Drivers | |||
| scanner problems | Vista General | |||
| Problems with bar code scanner | Virtual PC | |||
| Scanner problems | Vista print fax & scan | |||
| New Canon Scanner problems | Vista performance & maintenance | |||
