Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Samsung ML-1210: Haven't seen this problem before
Old 03-30-2008   #1 (permalink)
SAM
My wife has a new Compaq Presario F756NR running Vista Home Premium.
She has a Samsung ML-1210 laser printer that worked find under XP. I
installed the Vista Driver and when the install reached "Do you want
to print a test page?" I answered "yes." The printer "awoke" and the
data light on the printer began to flash but nothing printed.
I tried to print a Word document, the data light on the printer
flashed, and when I opened the printer window I could see that it had
received 64KB of nnnKB, then 128KB. But after that there was no
further movement until I got an error with no explanation.
After I flushed the print queue, and turned the printer off/on, I
created a very small text file with Notepad. This printed
successfully. But when I tried to print another Word document, I
experienced the same failure as previously.
Can anyone offer an explanation, or a clue?
Thanks very much.
Old 03-31-2008   #2 (permalink)
SAM
Re: Samsung ML-1210: Haven't seen this problem before
>Thanks very much.
Replying to my own post...
I probably would have received solutions to this problem if I had
included what turned out to be the most pertinent piece of info. I
originally connected to printer to the laptop via a Parallel/USB
cable. This morning, I replaced that with a pure USB cable (and
installed the Samsung USB driver) and everything seems fine now.
Canon Laser Shot LBP-1210 printer problem General Discussion
Driver problem Samsung CLP-300 VistaPremium 64bit Drivers
psc 1210 all in one printer - Label Problem Vista print fax & scan
Problem with HP 1210 Vista print fax & scan
Problem with Samsung 226BW monitor? Vista hardware & devices
Designer Media Ltd
