Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - DOT4_001 Problems with VISTA Ultimate SP1 HP Officejet K80
Old 03-31-2008   #1 (permalink)
Stokenking
::I try printing to this USB printer that connects to Dot4_001 printer
port but the printer does not react at all Print spooler reports error
restarts automatically and the errors again.::
::See event log entry below.::
::The printer could print, scan and fax before my SP1 update . Have
removed and reinstalled SP1 to no avail.::
::I am now trying to delete this port but the system will not allow me
to do so or how can I create a DOT4_002 port ?::
::PNP process does not seem to delete entry with printer disconnected
and after several reboots. Printer works using TCP port but then I
cannot scan and fax.::
System
- Provider
[ Name] Microsoft-Windows-PrintSpooler
[ Guid] {e4c60dfa-ecc5-4889-b406-e9ddd38463c8}
[ EventSourceName] Print
- EventID 6161
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2008-03-26T21:45:57.000Z
EventRecordID 22414
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel System
Computer King
- Security
[ UserID] S-1-5-21-4152463955-1577670197-1315543112-1000
- EventData
param1 Test Page
param2 Tom
param3 HP OfficeJet K80
param4 NT EMF 1.008
param5 196608
param6 0
param7 1
param8 0
param9 \\KING
param10 31
param11 A device attached to the system is not functioning.
Stokenking
Posted via http://www.vistaheads.com
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 Vista General
HP Officejet 7310 Vista x86 ultimate delayed printing until reboo Vista print fax & scan
HP Officejet Pro 7780 Printing Problems and Vista Vista print fax & scan
Dlink DI-524UP and HP Officejet 4355 with Windows Vista Ultimate Vista print fax & scan
HP Officejet 6110 - Has anyone got an officejet to print with Vista yet? Vista print fax & scan
