Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
RB
Vista - Installation Problems
04-16-2008   #1
Zygy
I used the HP Scanjet 5530 for some years.Then after some Microsoft
Automatic Updates for OS Vista Business (I cannot be certain that it was so)
it started misbehaving. I purchased a new HP Scanjet G3010, but I am
having problems installing it. Has anyone experienced such problems and if
so how did you overcome it?
04-17-2008   #2
William Anderson
RE: Installation Problems
Hey there Zygy,
are you getting a specific error when you try to install it? and also, are
you just using the CD? A lot of manufacturer driver cds haven't been updated
with the new drivers for vista yet, or you just got an older lot number.
Go here for the latest vista driver:
http://h20000.www2.hp.com/bizsupport...&swEnvOID=2093
Let me know how it goes!
Best Regards,
Will
RB
Similar Threads for: Installation Problems
Installation Problems Vista account administration
Installation ProblemS Vista account administration
Installation problems Vista General
Installation Problems Vista installation & setup
