Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - printing problems
Old 04-17-2008   #1 (permalink)
Vista Home Premium 32bit
printing problems
I have a problem with printing in windows photo gallery (vista). Every time
when I try to print a picture or text in windows photogallery the picture
(which is in portrait) is reshaped - and at the same time distorted - in
landscape format. What can I do about it?
Thanks,
Peter Ingelse
Printing problems Vista print fax & scan
Re: still problems with printing in ie7 Vista print fax & scan
Printing Problems Vista General
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
printing problems Vista print fax & scan
