Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - wireless install problem
Old 04-20-2008   #1 (permalink)
I've set up the Canon MF4100 printer and can print from the USB. I have the
Linksys WPSM54G print server installed and working on my XP laptop but can't
get it installed on my Vista 32 bit. The installation says to download
KB940199 but when run it says the computer does not need this update. I've
run the setup for the WPSM54G as administrator.
What next.
Old 04-21-2008   #2 (permalink)
Cari \(MS-MVP\)
Re: wireless install problem
Does Linksys have an update for the print server?
Cari (MS-MVP) Printing & Imaging
www.coribright.com/windows
<rpwinbuffalo@xxxxxx> wrote in message
news:O7vpWazoIHA.856@xxxxxx
> the Linksys WPSM54G print server installed and working on my XP laptop but
> can't get it installed on my Vista 32 bit. The installation says to
> download KB940199 but when run it says the computer does not need this
> update. I've run the setup for the WPSM54G as administrator.
> What next.
Old 04-21-2008   #3 (permalink)
I looked at that about two months ago but since it didn't say it was upated
for Vista, I figured it was the same as what I had on disk. I just now
downloaded what they had and now it works.
Thanks for your help - you don't know how happy I am to have it working.
"Cari (MS-MVP)" <newsgroups@xxxxxx> wrote in message
news:7C2474A9-FF1C-4BBA-A2EA-82DABBC54821@xxxxxx
>> but can't get it installed on my Vista 32 bit. The installation says to
>> What next.
Wireless Card Install Vista installation & setup
Can't install anything or conect to wireless Network & Sharing
Can't install my Wireless adapter Drivers
wireless not work after install SP1 Vista General
USB Wireless Adaptor Install Problem Vista hardware & devices
