| Member | Problem installing printer Hi, i had Vista X86 ultimate installed on my system, i have HP 6l gold printer, when i pulg in the wire it does not install the drivers and HP now not providing support for this printer. earlier when i m using XP there is no problem with drivers, XP install them automatically but in case of vista im facing problem. No driver support and i am also not able to add printer, i dont get the place to add printer like in other version i had check all the settings in control panel but i dont get the printer link or wizard to add printer manually. ![]() Please help me to use my printer. |
| Guest | Re: Problem installing printer Open your Control Panel and click on the "Add Hardware" icon*. The "Add Hardware Wizard" will appear. 1. Click on Next and place a dot next to "Yes, I have alrea*dy connected the hardware". 2. Click Next and scroll all the way down to "Add a new har*dware device". 3. Click once to highlight it and click Next. 4. Place a dot next to "Install the hardware that I manuall*y select from a list (Advanced)". 5. Click Next and scroll down to "Printers", click once to *highlight and click Next. 6. Place a dot next to "Use the following port" and click N*ext. 7. In the "Install Printer Software Screen", on the left si*de scroll down to "HP" and click once to highlight, then in the right-side scr*oll down to "HP LaserJet 6L", click on it to highlight, then *click Next to install the software. -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "alokyadav12" wrote: Hi, i had Vista X86 ultimate installed on my system, i have HP 6l gold printer, when i pulg in the wire it does not install the drivers and HP now not providing support for this printer. earlier when i m using XP there is no problem with drivers, XP install them automatically but in case of vista im facing problem. No driver support and i am also not able to add printer, i dont get the place to add printer like in other version i had check all the settings in control panel but i dont get the printer link or wizard to add printer manually. ![]() Please help me to use my printer. -- alokyadav12 |
| Member | Re: Problem installing printer hi, thanks for reply. I have seen this problem first time. when i try to add my printer by using add hardware from control panel it is not showing me the printer to select and all the other devices are there except printer and also not able to look where the printer settings in control panel. ![]() i had checked every thing but i dont see any thing to install the printer. 1. i dont get the printer in add hardware wizard 2. i dont see any link to printer in control panel as i seen in XP. 3. when i turn my start menu to classic i can able to see the printers folder but not able to add printer. i had tried every thing plz solve my problem thanks |
| Member | Re: Problem installing printer Hi, i have check on all the internet resorces for installing the driver and come to know that my vista does not have a dlls or service which is required for adding printer. please help me to get rid of this problem. |
| Guest | Re: Problem installing printer While your HP printer is connected to your computer and turned on: Visit the Windows Update web site and click on "Check for updates". After the scan is complete, click on "View available updates". Hopefully, a driver for your HP printer will be offered. -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "alokyadav12" wrote: Hi, i have check on all the internet resorces for installing the driver and come to know that my vista does not have a dlls or service which is required for adding printer. please help me to get rid of this problem. -- alokyadav12 |
| | #6 (permalink) |
| Member | Re: Problem installing printer Hi, thanks for quick reply. i checked it when i try to install drivers by using ad new hardware wizard there i select let me choose device, but in the list of device there i dont see the printer device to install drivers for printers. for eg there is a list of available devices like display,network adapters, etc. but there is no printer there, and also i dont see the link printers as it is in XP which shows the installed printers and from where we can also install printers. and i also dont have the printui.dll which is required to install printers. and no spooler file which starts the printer service. plz tell me how do i get this service running. i checked windows update site but i dont get any update regarding this problem. i also downloaded so many hotfixes and latest drivers for HP 6l gold printer. |
| | #7 (permalink) |
| Guest | Re: Problem installing printer Changes to a printer's device configuration are not applied until the computer restarts or the Print Spooler service restarts in Windows Vista: http://support.microsoft.com/kb/933454/en-us -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows Vista Enthusiast --------------------------------------------------------------- "alokyadav12" <guest@xxxxxx-email.com> wrote in message news:d59bb9492c648514a8f02b0c92b7de6d@xxxxxx-gateway.com... Hi, thanks for quick reply. i checked it when i try to install drivers by using ad new hardware wizard there i select let me choose device, but in the list of device there i dont see the printer device to install drivers for printers. for eg there is a list of available devices like display,network adapters, etc. but there is no printer there, and also i dont see the link printers as it is in XP which shows the installed printers and from where we can also install printers. and i also dont have the printui.dll which is required to install printers. and no spooler file which starts the printer service. plz tell me how do i get this service running. i checked windows update site but i dont get any update regarding this problem. i also downloaded so many hotfixes and latest drivers for HP 6l gold printer. -- alokyadav12 |
| | #8 (permalink) |
| Member | Re: Problem installing printer i have done restarting many times but no use, i dont have print spooler service in my services.msc and i installed this hotfix but of no use. |
| | #9 (permalink) |
| Guest | Re: Problem installing printer I have the same problem and can't seem to be able to get the printer working using Vista no matter what I do. "alokyadav12" wrote: Quote: > > i have done restarting many times but no use, i dont have print spooler > service in my services.msc and i installed this hotfix but of no use. > > > -- > alokyadav12 > |
| Problem installing HP Printer | Drivers | |||
| Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer | Vista print fax & scan | |||
| Problem installing Canon printer in Vista Ultimate 64 bit | Vista print fax & scan | |||
| Problem Installing Printer Driver | Vista hardware & devices | |||
| Problem Installing HP Printer on Vista | Vista hardware & devices | |||
