| | Problem installing Canon printer in Vista Ultimate 64 bit Just got a new PC with 64 bit Vista Ultimate and am having problems correctly installing a Canon Pixma MP760 multi function printer, scanner copier. I downloaded all the 64 bit drivers from the Canon website and installed them with no problems . Connected the printer and things seemed to go OK. The printer is registered fine in Device Manager under Imaging Devices with Properties saying this device is working properly. I can print OK and copy OK but am struggling with scanning. The canon software to scan is called MP Navigator 1.1 but when I click on the icon to launch I get the error message "The scanner driver supported by this software is not installed, Install it then retry". I try to update the driver software and get the message "Windows has determined the driver software for your device is up to date". So I have no way to amend any scans. I can scan from the printer itself (i.e. not the PC) but this gives for example 4 pages for a simple 1 page original. Have tried ringing Canon but they are a joke. Rang them from work and eventually had to concede and take a day off work to ring in front of the PC at home. Rang them and after 30 mins of a lady who kept putting me on hold and referring to an expert was told this would have to be passed to Level 2 support who would ring me in 2 or 3 days. Told them I work in office hours but they expect me to take a couple of further days off work to wait their call - cheaper to buy a new printer! Have tried the usual of uninstalling the printer and re-installing and also re downloaded the 64 bit software. In "Problem Reports and Solutions" 3 of the canon 64 bit drivers appear including the MP Navigator s/w (m6C18MUx.exe) all with the same message of Program Compatibility Problem. The problem given is Description This program might require administrator privileges (I am the administrator) Problem signature Problem Event Name: PCA2 Problem Signature 01: m6C18MUx.exe Problem Signature 02: 0.0.0.0 Problem Signature 03: m6C18MUx.exe Problem Signature 04: unknown Problem Signature 05: unknown Problem Signature 06: 8 Problem Signature 07: 202 OS Version: 6.0.6001.2.1.0.256.1 Locale ID: 2057 Files that help describe the problem appcompat.txt Attached, Am I flogging a dead horse and is it simply that the scanner drivers (which on the canon website say Windows Vista 64bit) just don't work or is their a solution I'm missing. I can get the scanner to work using Windows Photo Gallery but there are only a few adjustments you can make compared to the canon s/w. Appreciate any help. Cheers Steve |
| | Re: Problem installing Canon printer in Vista Ultimate 64 bit Did you install MP navigator 1.16? http://www.canon.ca/product_reg.asp?...rt%5Fby%3Ddflt -- Peter Toronto, Canada XP Pro SP2 x 2/Vista Ultimate SP1 Triple Boot "Stephen Flanagan" <stephen.flanagan2@xxxxxx> wrote in message news:%23ixR$MUrIHA.1872@xxxxxx Quote: > Just got a new PC with 64 bit Vista Ultimate and am having problems > correctly installing a Canon Pixma MP760 multi function printer, scanner > copier. I downloaded all the 64 bit drivers from the Canon website and > installed them with no problems . Connected the printer and things seemed > to go OK. The printer is registered fine in Device Manager under Imaging > Devices with Properties saying this device is working properly. > > I can print OK and copy OK but am struggling with scanning. The canon > software to scan is called MP Navigator 1.1 but when I click on the icon > to > launch I get the error message "The scanner driver supported by this > software is not installed, Install it then retry". I try to update the > driver software and get the message "Windows has determined the driver > software for your device is up to date". So I have no way to amend any > scans. I can scan from the printer itself (i.e. not the PC) but this > gives > for example 4 pages for a simple 1 page original. > > Have tried ringing Canon but they are a joke. Rang them from work and > eventually had to concede and take a day off work to ring in front of the > PC > at home. Rang them and after 30 mins of a lady who kept putting me on hold > and referring to an expert was told this would have to be passed to Level > 2 > support who would ring me in 2 or 3 days. Told them I work in office > hours > but they expect me to take a couple of further days off work to wait their > call - cheaper to buy a new printer! > > Have tried the usual of uninstalling the printer and re-installing and > also > re downloaded the 64 bit software. In "Problem Reports and Solutions" 3 > of > the canon 64 bit drivers appear including the MP Navigator s/w > (m6C18MUx.exe) all with the same message of Program Compatibility > Problem. > The problem given is > > Description > This program might require administrator privileges (I am the > administrator) > > Problem signature > Problem Event Name: PCA2 > Problem Signature 01: m6C18MUx.exe > Problem Signature 02: 0.0.0.0 > Problem Signature 03: m6C18MUx.exe > Problem Signature 04: unknown > Problem Signature 05: unknown > Problem Signature 06: 8 > Problem Signature 07: 202 > OS Version: 6.0.6001.2.1.0.256.1 > Locale ID: 2057 > > Files that help describe the problem > appcompat.txt > > Attached, > > Am I flogging a dead horse and is it simply that the scanner drivers > (which > on the canon website say Windows Vista 64bit) just don't work or is their > a > solution I'm missing. > > I can get the scanner to work using Windows Photo Gallery but there are > only > a few adjustments you can make compared to the canon s/w. > > Appreciate any help. > > Cheers > > Steve > |
| | Re: Problem installing Canon printer in Vista Ultimate 64 bit Peter, Yes I had installed version 1.16 (although the icon on my desktop just says 1.1). I did uninstall and use your link and re-downloaded but still get the same Error Message stating "The scanner driver supported by this software is not installed, Install it then retry". I see from your link that are higher (newer) Vista versions i.e. Vista 64 2.02 tried them but no luck either. Thanks anyway. Steve "Peter" <nobody@xxxxxx> wrote in message news:ekCeh8WrIHA.1436@xxxxxx Quote: > Did you install MP navigator 1.16? > > http://www.canon.ca/product_reg.asp?...rt%5Fby%3Ddflt > > -- > Peter > Toronto, Canada > XP Pro SP2 x 2/Vista Ultimate SP1 > Triple Boot > > "Stephen Flanagan" <stephen.flanagan2@xxxxxx> wrote in message > news:%23ixR$MUrIHA.1872@xxxxxx Quote: >> Just got a new PC with 64 bit Vista Ultimate and am having problems >> correctly installing a Canon Pixma MP760 multi function printer, scanner >> copier. I downloaded all the 64 bit drivers from the Canon website and >> installed them with no problems . Connected the printer and things >> seemed >> to go OK. The printer is registered fine in Device Manager under Imaging >> Devices with Properties saying this device is working properly. >> >> I can print OK and copy OK but am struggling with scanning. The canon >> software to scan is called MP Navigator 1.1 but when I click on the icon >> to >> launch I get the error message "The scanner driver supported by this >> software is not installed, Install it then retry". I try to update the >> driver software and get the message "Windows has determined the driver >> software for your device is up to date". So I have no way to amend any >> scans. I can scan from the printer itself (i.e. not the PC) but this >> gives >> for example 4 pages for a simple 1 page original. >> >> Have tried ringing Canon but they are a joke. Rang them from work and >> eventually had to concede and take a day off work to ring in front of the >> PC >> at home. Rang them and after 30 mins of a lady who kept putting me on >> hold >> and referring to an expert was told this would have to be passed to Level >> 2 >> support who would ring me in 2 or 3 days. Told them I work in office >> hours >> but they expect me to take a couple of further days off work to wait >> their >> call - cheaper to buy a new printer! >> >> Have tried the usual of uninstalling the printer and re-installing and >> also >> re downloaded the 64 bit software. In "Problem Reports and Solutions" 3 >> of >> the canon 64 bit drivers appear including the MP Navigator s/w >> (m6C18MUx.exe) all with the same message of Program Compatibility >> Problem. >> The problem given is >> >> Description >> This program might require administrator privileges (I am the >> administrator) >> >> Problem signature >> Problem Event Name: PCA2 >> Problem Signature 01: m6C18MUx.exe >> Problem Signature 02: 0.0.0.0 >> Problem Signature 03: m6C18MUx.exe >> Problem Signature 04: unknown >> Problem Signature 05: unknown >> Problem Signature 06: 8 >> Problem Signature 07: 202 >> OS Version: 6.0.6001.2.1.0.256.1 >> Locale ID: 2057 >> >> Files that help describe the problem >> appcompat.txt >> >> Attached, >> >> Am I flogging a dead horse and is it simply that the scanner drivers >> (which >> on the canon website say Windows Vista 64bit) just don't work or is >> their a >> solution I'm missing. >> >> I can get the scanner to work using Windows Photo Gallery but there are >> only >> a few adjustments you can make compared to the canon s/w. >> >> Appreciate any help. >> >> Cheers >> >> Steve >> |
| | Re: Problem installing Canon printer in Vista Ultimate 64 bit I would go back to Canon and hope this time you get someone intelligent. They are usually pretty helpful. -- Peter Toronto, Canada XP Pro SP2 x 2/Vista Ultimate SP1 Triple Boot "Stephen Flanagan" <stephen.flanagan2@xxxxxx> wrote in message news:%23AJebQdrIHA.4280@xxxxxx Quote: > Peter, > > Yes I had installed version 1.16 (although the icon on my desktop just > says 1.1). I did uninstall and use your link and re-downloaded but still > get the same Error Message stating "The scanner driver supported by this > software is not installed, Install it then retry". I see from your link > that are higher (newer) Vista versions i.e. Vista 64 2.02 tried them but > no luck either. > > Thanks anyway. > > Steve > > > > "Peter" <nobody@xxxxxx> wrote in message > news:ekCeh8WrIHA.1436@xxxxxx Quote: >> Did you install MP navigator 1.16? >> >> http://www.canon.ca/product_reg.asp?...rt%5Fby%3Ddflt >> >> -- >> Peter >> Toronto, Canada >> XP Pro SP2 x 2/Vista Ultimate SP1 >> Triple Boot >> >> "Stephen Flanagan" <stephen.flanagan2@xxxxxx> wrote in message >> news:%23ixR$MUrIHA.1872@xxxxxx Quote: >>> Just got a new PC with 64 bit Vista Ultimate and am having problems >>> correctly installing a Canon Pixma MP760 multi function printer, scanner >>> copier. I downloaded all the 64 bit drivers from the Canon website and >>> installed them with no problems . Connected the printer and things >>> seemed >>> to go OK. The printer is registered fine in Device Manager under >>> Imaging >>> Devices with Properties saying this device is working properly. >>> >>> I can print OK and copy OK but am struggling with scanning. The canon >>> software to scan is called MP Navigator 1.1 but when I click on the icon >>> to >>> launch I get the error message "The scanner driver supported by this >>> software is not installed, Install it then retry". I try to update the >>> driver software and get the message "Windows has determined the driver >>> software for your device is up to date". So I have no way to amend any >>> scans. I can scan from the printer itself (i.e. not the PC) but this >>> gives >>> for example 4 pages for a simple 1 page original. >>> >>> Have tried ringing Canon but they are a joke. Rang them from work and >>> eventually had to concede and take a day off work to ring in front of >>> the PC >>> at home. Rang them and after 30 mins of a lady who kept putting me on >>> hold >>> and referring to an expert was told this would have to be passed to >>> Level 2 >>> support who would ring me in 2 or 3 days. Told them I work in office >>> hours >>> but they expect me to take a couple of further days off work to wait >>> their >>> call - cheaper to buy a new printer! >>> >>> Have tried the usual of uninstalling the printer and re-installing and >>> also >>> re downloaded the 64 bit software. In "Problem Reports and Solutions" 3 >>> of >>> the canon 64 bit drivers appear including the MP Navigator s/w >>> (m6C18MUx.exe) all with the same message of Program Compatibility >>> Problem. >>> The problem given is >>> >>> Description >>> This program might require administrator privileges (I am the >>> administrator) >>> >>> Problem signature >>> Problem Event Name: PCA2 >>> Problem Signature 01: m6C18MUx.exe >>> Problem Signature 02: 0.0.0.0 >>> Problem Signature 03: m6C18MUx.exe >>> Problem Signature 04: unknown >>> Problem Signature 05: unknown >>> Problem Signature 06: 8 >>> Problem Signature 07: 202 >>> OS Version: 6.0.6001.2.1.0.256.1 >>> Locale ID: 2057 >>> >>> Files that help describe the problem >>> appcompat.txt >>> >>> Attached, >>> >>> Am I flogging a dead horse and is it simply that the scanner drivers >>> (which >>> on the canon website say Windows Vista 64bit) just don't work or is >>> their a >>> solution I'm missing. >>> >>> I can get the scanner to work using Windows Photo Gallery but there are >>> only >>> a few adjustments you can make compared to the canon s/w. >>> >>> Appreciate any help. >>> >>> Cheers >>> >>> Steve >>> |
| | Re: Problem installing Canon printer in Vista Ultimate 64 bit Stephen Flanagan;3710363 Wrote: Quote: > Just got a new PC with 64 bit Vista Ultimate and am having problems > correctly installing a Canon Pixma MP760 multi function printer, > scanner > copier. I downloaded all the 64 bit drivers from the Canon website > and > installed them with no problems . Connected the printer and things > seemed > to go OK. The printer is registered fine in Device Manager under > Imaging > Devices with Properties saying this device is working properly. > > I can print OK and copy OK but am struggling with scanning. The canon > software to scan is called MP Navigator 1.1 but when I click on the > icon to > launch I get the error message "The scanner driver supported by this > software is not installed, Install it then retry". I try to update > the > driver software and get the message "Windows has determined the driver > software for your device is up to date". So I have no way to amend > any > scans. I can scan from the printer itself (i.e. not the PC) but this > gives > for example 4 pages for a simple 1 page original. > > Have tried ringing Canon but they are a joke. Rang them from work and > eventually had to concede and take a day off work to ring in front of > the PC > at home. Rang them and after 30 mins of a lady who kept putting me on > hold > and referring to an expert was told this would have to be passed to > Level 2 > support who would ring me in 2 or 3 days. Told them I work in office > hours > but they expect me to take a couple of further days off work to wait > their > call - cheaper to buy a new printer! > > Have tried the usual of uninstalling the printer and re-installing and > also > re downloaded the 64 bit software. In "Problem Reports and Solutions" > 3 of > the canon 64 bit drivers appear including the MP Navigator s/w > (m6C18MUx.exe) all with the same message of Program Compatibility > Problem. > The problem given is > > Description > This program might require administrator privileges (I am the > administrator) > > Problem signature > Problem Event Name: PCA2 > Problem Signature 01: m6C18MUx.exe > Problem Signature 02: 0.0.0.0 > Problem Signature 03: m6C18MUx.exe > Problem Signature 04: unknown > Problem Signature 05: unknown > Problem Signature 06: 8 > Problem Signature 07: 202 > OS Version: 6.0.6001.2.1.0.256.1 > Locale ID: 2057 > > Files that help describe the problem > appcompat.txt > > Attached, > > Am I flogging a dead horse and is it simply that the scanner drivers > (which > on the canon website say Windows Vista 64bit) just don't work or is > their a > solution I'm missing. > > I can get the scanner to work using Windows Photo Gallery but there are > only > a few adjustments you can make compared to the canon s/w. > > Appreciate any help. > > Cheers > > Steve Driver but also the other Canon 64bit Navigator and other drivers avaliable and install... regards carl... -- carlsf ------------------------------------------------------------------------ carlsf's Profile: http://forums.techarena.in/members/carlsf.htm View this thread: http://forums.techarena.in/vista-print-fax/961320.htm http://forums.techarena.in |
| Canon S9000 printer problem | Drivers | |||
| Driver Problem with Canon LBP2900 Printer | Vista hardware & devices | |||
| Installing Driver for Canon MP180 printer in vista - access denied | Vista General | |||
| Re: vista x64 - XPhome x86 Canon printer problem | Vista print fax & scan | |||
