Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Re: IE7 will not print after updates
Old 05-10-2008   #1 (permalink)
PA Bear [MS MVP]
Forwarded to Vista Print_Fax_Scan newsgroup via crosspost.
~Robear Dyer (PA Bear)
MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002
AumHa VSOP & Admin http://aumha.net
DTS-L http://dts-l.net/
teezedd wrote:
Quote:
> IE7 will no longer allow printing after the following Vista updates
> done on 5/7/2008. I do not get any error messages.
> Update for Windows Vista (KB940510) Installation date: ý5/ý7/ý2008
> 9:40 AM Installation status: Successful Update type: Important
> Microsoft Office PowerPoint Viewer 2007 Service Pack 1 (SP1)
> Installation date: ý5/ý7/ý2008 9:40 AM Installation status: Successful
> Microsoft Office Compatibility Pack Service Pack 1 (SP1) Installation
> date: ý5/ý7/ý2008 9:41 AM Installation status: Successful
> 2007 Microsoft Office Suite Service Pack 1 (SP1) Installation date:
> ý5/ý7/ý2008 9:43 AM Installation status: Successful
> Hotfix for Windows (KB929547) Installation date: ý5/ý7/ý2008 10:01 AM
> The printer icon shows in the task bar but it shows 0 documents
> pending and nothing prints. It appears the file is not being spooled
> to the printer. I can print in all Office programs but not in IE7.
> By turning off the Protected Mode in IE7 I am able to print but that
> is not a suitable solution.
> I have deleted the HP 7200 network printer and reinstalled the driver
> and that did not help.
> I do have a Low folder C:\Users\YourName\AppData\Local\Temp\Low It
> has a number of items and 4 sub folders.I do not know if the folder
> now has the required integrity level. I also have a sub Low folder in
> my Low folder and it is empty. C:\Users\YourName\AppData\Local\Temp
> \Low\Low.
> I wonder if this second low folder is creating the problem?
Old 05-10-2008   #2 (permalink)
Vista Ultimate
I have had this same problem, now about 4 weeks old. Unfortunately nobody seems to have an answer. There was a similar posting on this site yesterday, but, again, I don't think any replies were made.
I am currently waiting for HP to get back to me!!!
Really odd thing is I have a simple P2P network setup. One PC runs Vista Ultimate SP1, the other XP Pro SP3 and everything prints fine on this PC. I can only conclude that its got something to do with Vista, or Vista SP1!!! Even tried Microsoft's free support for problems arising from installing SP1, but, yet again, no resolution. I shall watch this posting, just in case someone comes up with a solution, but I don't hold out much hope?
Good luck, Algypalgy
Vista Machine Takes Over Print - XP Printers Can't Print Afterwards Vista networking & sharing
Vista Can't Print to Win2K shared printer-Test Print disappears fr Vista networking & sharing
Unable to Print or Print Preview from IE7 on Vista Home Premium Vista print fax & scan
After printing several documents, the print queue hangs, print st Vista print fax & scan
print driver successfully installed but still a problem with print Vista print fax & scan
