Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Re: Lexmark 8350 Vista print problem on a network
Old 05-12-2008   #1 (permalink)
bjr
The Lexmark owner with this problem ( a senior) finally got back to me.
Using remote assistance, I tried the copyfilename
\\XPmachine\printershare command from his Vista laptop (wireless to
Belkin router) (XP machine is wired to the Belkin, Lexmark 8350 AIO set
up on this computer).
When the command is executed from a Vista laptop admin cmd window using
a file saved as a print saved to a file (*.prn), the printer prints a
blank page.
Alan Morris [MSFT] wrote:
Quote:
> The USB port speed should not make any difference.
> When you create a Local Port using \\XPmachine\printershare you
basically
Quote:
> copy the file to the other machine
> Can you print to file on the Vista machine then copy the print file to
> \\XPmachine\printershare?
> you will need to open a command prompt
> copy filename \\XPmachine\printershare
Lexmark z705 test print but won't print Vista print fax & scan
Lexmark 8350 Photo Card save to computer Vista print fax & scan
Problem installing Lexmark x4650 - error 0x000006be, Print Spooler, Add Printer Vista print fax & scan
Lexmark Z515 Printer won't print with Vista Vista hardware & devices
Lexmark 8350 Vista print problem on a network Vista print fax & scan
