| | Default Printer Issue - Again! As has been raised a number of times on this group, I'm having an issue with retaining the default printer setting. We are running our initial 12 machine deployment of Vista Enterprise with SP1 installed, along with 1 Vista Ultimate with SP1. All users, including administrators, have the same issue, which is that after a reboot, the previously selected default printer has not been retained and has reverted to one of the local printers. In the case of clean builds this is one of XPS or Fax, but we do have machines with specialised label printers attached and this will become the default - as such the previously described solution of removing local printers is not a suitable workaround. This is clearly a bug in Vista's handling of print defaults for users and needs to be looked at asap, as it quickly becomes a source of irritation to users and hence I.T. (ie ME) |
| Vista - default printer doesn't stay as default | Vista print fax & scan | |||
| Setting a default printer for the DEFAULT USER | Vista print fax & scan | |||
| Vista Printer Default Printer Issues | Vista print fax & scan | |||
| Vista keeps stealing default status from default printer computer | Vista networking & sharing | |||
| Re: Anybody else's default printer not staying default? | Vista print fax & scan | |||
