| 32bit | Print too small to read.. My printer is a Lexmark - (x-8350) All in One ---- Driver compatible with Vista is installed. The print is so small I need a magnifying glass to read it. I have attempted what adjustments I could make and nothing happens. I have contacted Lexmark and the help they provided me was minimal. I have never had this problem before and all of it sudden it pops up. I have new cartridges installed, however, not only is the print tiny, but the print is extremely light. Thank you in advance for whatever assistance you may be able to provide me. I just kind of hate to have to go out and get a new printer without knowing if something can be to done to solve this problem. Thank you again. |
| | Re: Print too small to read.. Does it print correctly for any application (prints OK from Notepad, for example, but not from IE), or do you see this printing from all applications? Hal -- Hal Hostetler, CPBE -- hhh@xxxxxx Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX http://www.kvoa.com -- "When News breaks, we fix it!" KVOA Television, Tucson, AZ. NBC Channel 4 Live at Hot Licks - www.badnewsbluesband.com "Evitta" <guest@xxxxxx-email.com> wrote in message news:844dd0962935978c824ef7d4b74a376b@xxxxxx-gateway.com... Quote: > > My printer is a Lexmark - (x-8350) All in One ---- Driver compatible > with Vista is installed. The print is so small I need a magnifying > glass to read it. I have attempted what adjustments I could make and > nothing happens. I have contacted Lexmark and the help they provided > me was minimal. I have never had this problem before and all of it > sudden it pops up. I have new cartridges installed, however, not only > is the print tiny, but the print is extremely light. Thank you in > advance for whatever assistance you may be able to provide me. I just > kind of hate to have to go out and get a new printer without knowing if > something can be to done to solve this problem. Thank you again. > > > -- > Evitta |
| 32bit | Re: Print too small to read.. Thank you for your response. In answer to your question. Everthing that I print, from wherever, all print the same way --- very tiny and very light print. Thank you again. |
| | Re: Print too small to read.. It sounds like the default font on the device is set. Print the configuration page from the device and check. I've seen this on other Lexmark devices. I don't recall if there is a setting in the driver. Check font substitution settings. If device fonts are substituted and nothing downloaded to the device, then this would make sense. -- Alan Morris Windows Printing Team Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/?adv=1 This posting is provided "AS IS" with no warranties, and confers no rights. "Evitta" <guest@xxxxxx-email.com> wrote in message news:b26ecbf26b344bb0be81fafdb3c79460@xxxxxx-gateway.com... Quote: > > Thank you for your response. In answer to your question. Everthing > that I print, from wherever, all print the same way --- very tiny and > very light print. Thank you again. > > > -- > Evitta |
| | Re: Print too small to read.. Thanks, Allen! I'm not familiar with that particular printer, so I have no idea where to tell her to look, but it does, indeed, sound like a default font issue. Hal -- Hal Hostetler, CPBE -- hhh@xxxxxx Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX http://www.kvoa.com -- "When News breaks, we fix it!" KVOA Television, Tucson, AZ. NBC Channel 4 Live at Hot Licks - www.badnewsbluesband.com "Alan Morris [MSFT]" <alanmo@xxxxxx> wrote in message news:u6gy9YDvIHA.516@xxxxxx Quote: > It sounds like the default font on the device is set. Print the > configuration page from the device and check. I've seen this on other > Lexmark devices. I don't recall if there is a setting in the driver. Quote: > font substitution settings. If device fonts are substituted and nothing > downloaded to the device, then this would make sense. > > > -- > Alan Morris > Windows Printing Team > Search the Microsoft Knowledge Base here: > http://support.microsoft.com/search/?adv=1 > > This posting is provided "AS IS" with no warranties, and confers no Quote: > > "Evitta" <guest@xxxxxx-email.com> wrote in message > news:b26ecbf26b344bb0be81fafdb3c79460@xxxxxx-gateway.com... Quote: > > > > Thank you for your response. In answer to your question. Everthing > > that I print, from wherever, all print the same way --- very tiny and > > very light print. Thank you again. > > > > > > -- > > Evitta > |
| Too Small to Read | Vista mail | |||
| An additional Small box opens with email when click on read messag | Vista mail | |||
| Print from hotmail addy is very small | Vista print fax & scan | |||
| Printer's copies small to read | Vista hardware & devices | |||
| type too small to read | Vista performance & maintenance | |||
