Go Back   Vista Forums > Vista Newsgroups > Vista print fax & scan
Vista - Help - Configuring print router
Old 05-24-2008   #1 (permalink)
djinnc
I am trying to use existing Belkin print server with new laptop (Vista). I
am not able to manually configure the printer port. I have changed
administrator permissions, but when I click on "configure", it says there's
nothing to configure. I set up as USB local printer port, and have also
tried creating a new port, and still can't get it to work. Any ideas on how
to get the port configured?
Configuring the LPT port in Vista to be able to print a DOS applic Vista print fax & scan
XP + Vista + Router + Print Server = HELP!!! Vista networking & sharing
Wireless Print Router/hub Vista print fax & scan
Configuring 2WIRE Wireless Router in Windows Vista Vista installation & setup
Print from laptop using router Vista networking & sharing
